Question about T-View TView (DVD170TV) Motorized 7" In-Dash Widescreen TFT/LCD Monitor with DVD Player, AM/FM/TV Tuner and... Car Video Player
Tview bought a tview in dash but need a plug for the radio not the wiring harness
  • nottaglumlot Jul 16, 2008
    it powers up for about 10 seconds, then lights go off, and nothing happens
savers2008
  • 286 Answers
SOURCE: why won't youtube videos play on my tview in dash
This could be because your DVD wont accept the format that YouTube use. I believe they use ( .FLV )
What you need to do is to convert it to .MPEG format to play on dvd or DVD format .VOB..
There is a very good converter on the internet called Pazera. Click on the link below and download it. ITS FREE.
http://download.cnet.com/Pazera-Free-FLV-to-AVI-Converter/3000-2194_4-10786669.html
Hope this helps.
Posted on Apr 15, 2011
Hi I've got a 62 transit and want to change the battery but don't have the radio code can I get it off the radio while its still connected
No you will need to contact a ford dealer or the dealer for the radio manufacturer to get the code from them
Jan 11, 2017 | Car Audio & Video
Where can I find the memory wire for the radio
Car radios don't have a 'memory wire'. Memory is held in integrated circuit chips called EPROMS, (electronically programmable, read only modules).
Jan 08, 2017 | Car Audio & Video
I have a boss 400w riot 2-4 channels,how do i connect the high level wires? Because stereo doesn't have rca's
to use the high level leads, you have to isolate the wires going to each speaker (if using 4 channel mode) or isolate the wires going just to the rear if you are using 2 channel mode. you have to strip a small piece of the insulation off each speaker wire, and run it into the amps high level input harness. if you dont have the high level input harness, you can get a 2 channel high level to rca adapter for around $20. basically, you are tapping into the signal to the stock speakers to feed music to the amp. make sure you get all your positives and negatives correct. brighter wires are usually positive; however you may be faced with sa speaker which uses a grey wire, and another grey wire- the second with a black line. you will have to, again, turn to internet research to determine which is positive and negative, if the colors are not obvious.
Dec 30, 2016 | Boss Car Audio & Video
Try change my car radio cd .after connecting electric power and audio cable the new radio panasonic start 1 minute and stop loss power i reconnecting the old car radio ask me for cood the car is
You need to enter the radio code.....this should be with the service book or handbook, or contact the main dealer who will have a record of the code!
Jan 26, 2015 | Car Audio & Video
Where can I find the connections the go on the back of the stereo
Usually behind the stereo in the console. Either a square or rectangle in shape. You can obtain adapters for differing units that allows the use of the original wiring harness without rewiring. Just a simple plug and play option.
Jan 01, 2015 | Car Audio & Video
How to reset eclipse avn51d?
www.eclipse-web.com/us
Jul 13, 2014 | Car Audio & Video
I need the power plug wire harness that u hook the speakers up
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Electro help
Jun 17, 2014 | Car Audio & Video
Car radio not turning off when the car is turn off
This has to do with the way the radio is wired. It's best to go into a motor-mechanics or car-audio shop to have them wire it correctly
Jun 09, 2014 | Car Audio & Video
1992 GOLDWING RADIO SPEAKERS NOT WORKING
All you can do is trace the wiring back from the radio to the speakers, there is no quick fix here. To test the speakers touch a battery to the two contacts, the speaker will pop if it is any good.
Nov 06, 2012 | Car Audio & Video
Car Audio & Video Logo
89 people viewed this question
Top T-View Car Audio & Video Experts
Brandon Berry
Brandon Berry
Dan Apthorp
Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
