Question about Zanussi Washing Machines
Fitting new door seal to fl 850 - Zanussi Washing Machines
  • gezlu Jun 27, 2008
    It is a Zanussi FL 1085.Is it a Big Job?
  • douglas smith May 11, 2010
    what make is it? sounds like a zanussi model number but not sure. let me know and i'll give you instructions
    President:
  • 1,462 Answers
Not a big job but you may need an extra pair of hands as one part is awkward.
remove plastic clip that holds seal to cabinet - i prise clip of with a screwdriver. unpeel seal from cabinet and fold it inside the drum.
the seal is held onto tub with a large circular spring. push bottom of seal down and pull out and seal will come off together with spring.
now comes the awkward bit
lubricate the groove that fits onto the tub with washing up fluid all round. starting at top, push groove onto lip of tub. with thumbs, work all the way round in opposite directions with each hand until seal is completely located on lip of tub. this is quite hard to do so you may have to try several time but don't despair. fold the seal into the drum to make the next bit easier
next the spring has to be located which is where a second pair of hands will be helpful
start the spring at the top into the external groove of the seal and just work round till the spring slips into the groove. its harder than it sounds and four hands makes it a lot easier.
slip the seal onto the cabinet (easy bit) and fit the plastic clip
test for leaks using the rinse cycle (water level is higher)
this job used to take me under 5 mins and it is a real knack but is not really that hard. you can do it! the trick is always lubricate with washing up fluid
go for it
doug
if you run into problems, email me direct on frogmorebissoe@hotmail.com
Posted on Jun 28, 2008
Door seals are in a formed groove/slot.Grab the one end and pull the seal out.Putting the new one in is harder.Use a light lubricant,like vasoline,that will just dissipate after a while,and gently pull the new seal into the groove/slot.I've had to do this myself.
May 01, 2014 | 2002 Mitsubishi Diamante
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
I HAVE A LEAKING SUNROOF WHERE CAN I GET RUBBER SEAL FOR A VOLVO 850 SUNROOF?
It will be good to use the one that is used OE in the car which can be sourced from Volvo service dealership.
However if you are thinking of a replacement type there are many that can be sourced from glass fabrication agents, car accessories retails shops.
I would reccommend tthe same type to be used for the fitting to the frame. use this right glue for fixing the gasket tightly.
Aug 29, 2010 | 1996 Volvo 850
How to replace the door seal on a Simpson Silencio 850 Dishwasher Model No. 82B850WH. The part No. that I have for the door seal is 0208400158G & is Electrolux part number
The around the tank seal just pushes into the groove. make sure that you copy the way the old one comes out. The bottom of the door seal is a bit awkward. Thsi has some screws that are difficult to access. Take the door liner off and possibly two of the hinge screws so that the door can swing up at the bottom to allow easy access to the screws. You might get someone to help ny holding the door while you do this. Check tah the new seal fits the same way as the old one comes out. Then reassemble
Aug 01, 2010 | Dishwashers
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Need to replace the door gasket. Can this be done with the door on?
    Door on is the preferred method for me. Once you take it off and place it on the floor you can break the handle. (must remove the handle if you remove the door or place it on blocks of wood. (IF you remove it)
    It is a matter of loosening the screws removing the old door seal and fitting the new door seal in place.
    (Tighten the seal mounting / hold down screws when your done fitting the new seal.)
    Thanks for using FixYa!
    Kelly
    Feb 19, 2010 | Washing Machines
    Replaced door seal now door is difficult to close.
    Sometimes, it is hard to close door after fitting a new seal.
    Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
    Try smearing the door glass with washing up liquid, this can help to close the door more easily
    Please rate my solution.
    Thankyou.
    Feb 13, 2010 | Ariston Technologies Washing Machines
    Fitting a door seal to a Zanussi ZWD 1270SA washing/drier
    Follow these steps to replace your door seal:
    For all Free appliance repair videos visit our VIDEO TUTORIALS
    Disconnect all power to the machine first!!
    1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
    2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
    3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
    4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
    5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
    6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
    7 now fit the outer band and the test the machine for any leaks,
    All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
    Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
    Dec 28, 2009 | Zanussi ZWF1440 Front Load Washer
    FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
    this is a complex repair and the machine complet frount has to be removed
    May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
    Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
    Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
    Washing Machines Logo
    229 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
