Question about Panasonic KX-T7730 Corded Phone
STORE NO FOR ONE TOUCH DIALLING
HOW TO STORE NOS FOR ONE TOUCH DIALLING & HOW TO DIAL
  • dlevy42 Apr 24, 2009
    how do i deactivate one touch dialing ?i used my line 1 extension and now i cant dial out
  • Anonymous May 20, 2009
    i was able to store the numbers but when i tried to call it i cannot make it. Please help me on this...
  • 30 Answers
Press prog. button then press the one touch button, press 2 then 9 or 0 (depending in your line access no.) enter the contact no. then press store button.
Posted on Jul 25, 2008
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
I set the One-Touch Dialling to CO. Please teach me how to cancel this setting.
The only buttons you can set to CO are the left side buttons with lights, so assuming that, press PROGRAM the button dial 2 STORE. That clears the button. Now, just in case you lost the sequence of buttons for outside lines, from the bottom press the left side buttons and read them. If they're not in 1234 sequence, dial 0x STORE to restore the CO line that belongs there.
Carl
Jul 01, 2011 | Panasonic KX-T7730 Corded Phone
I have programmed the one-touch dialling but this has caused the little red light on the outside line button not to display with incoming or outgoing calls. Im at reception and this function was great but...
No, post here, read here, no email to you.
Press PROGRAM and the button you unprogrammed. If it's a CO line, dial 0 + 001,002,003 or whatever and STORE. That puts the lines back under the buttons.
Carl
Mar 23, 2011 | Panasonic KX-T7630 Corded Phone
How do I programme the memory on an answercall sp100 phone?
1. Pick up handset OR press 'handsfree' and wait for dialling tone.
2. Press 'store'.
3. Dial number you wish to put in the memory.
4. Either press 'M1', 'M2' or 'M3' to save as one touch speed dial numbers OR press 'store' again and then press any number between 0 - 9 to save two touch speed dial.
5. Replace handset and you're done.
In future if you wish to dial a one touch number then so long as you remember which button you ascribed to it you can do so with M1, M2 or M3. If it was a two touch number then you will need to press 'memory' followed by whatever number you ascribed between 0 - 9.
Hope this helps!
D. Nisbet
Sep 12, 2010 | Cell Phones
Panasonic KX-T7730
With the handset still on the cradle press program and then the desired one-touch button. Now press 0 followed by the desired CO line example 1 or 2. Now press the Auto Dial / Store button to save the changes. Press program to exit programming mode.
Please rate if this answer was helpfull
Thank you
Feb 03, 2010 | Panasonic KX-T7730 Corded Phone
HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
Carl
Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
How do you save numbers for one touch dialling?
Press PROG the button and dial 2 + 9 + the number and STORE.
If your outside line access code is something different, insert it instead of "9".
carl
May 20, 2009 | Panasonic KX-T7630 Corded Phone
Ntld1101 - setting up touch tone dialling
how do i set up touch dial on my cordless phone
Apr 10, 2009 | NTL VS1500 Cordless Phone
We cannot make an indirect call using polycon soundstation2
it appears u have connected it to the epabx extension. when u try nos first & then press call, the unit dials the nos so fast that it does not understand ur access number (0 or 9) for dialling out.for this u need to give a pause between the access number ( 0 or 9 to get the dial tone for diallin an external no)this is available on the keypad as pause / redial & then out the number & press call.the prob should get fixed!
Sep 23, 2008 | Polycom SOUNDSTATION2 AVAYA 2490...
One touch dial or speed dialling.
Hi Menu => Contacts =>Speed dials. Good luck.
Aug 28, 2007 | Nokia 1100
Panasonic KX-T7730 Corded Phone Logo
490 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
