Wide screen adjustment does not hold keeps going to default narrow screen
  • 63 Answers
Most analogue TV's do this because the analogue signal has no way to tell the TV that its a widescreen picture.
European TV's that use scart cables have a switching pin on the cable so the digital set top box can tell the TV that the picture is widescreen.
If you're in the US or down under this info wont be much help though.
Hope this helps
Andy
Posted on Jun 26, 2008
How do I narrow the scan beam on the n410
The scan beam is fixed and can not be adjusted. However moving the n410 closer to the bar code will reduce the width of the beam itself. The narrow beam is designed to accommodate static stands as well as manual use.
Simply hold the n410 a few inches away from the bar code and the beam will be able to read the code underneath. No adjustment except the distance between the n410 and the barcode is required.
Nov 24, 2014 | Computers & Internet
Monitor display width to wide
You should first check the native resolution of the replacement monitor, then set windows to use that resolution.
Dec 18, 2011 | Computers & Internet
How to tie a necktie
Welcome to Fixya.
Here's a comprehensive guide on how to tie a necktie in different styles :
Thanks for using Fixya.
Jun 25, 2011 | Computers & Internet
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
Jul 04, 2010 | LG Flatron W2242P-SF 22" Monitor
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
I have a new flat screen monitor, thats oblong in shape and my eyes are going nuts because its all stretched out and i want it square looking.how can i change it?
This is common with wide screens and the screen resolution needs to be adjusted to keep the correct aspect ratio.
My method, open MS Word - new document then Click on Insert - Picture - Autoshape and select a circle and place this shape in the document. Then if you wish to make the shape larger, then hold down the Shift key and drag the corner box to make the shape larger.
NOTE by holding down the Shift key, the circle will keep its shape and not distort.
Now Click on Control panel - Display - Settings and adjust the screen resolution and then view the Word doc with the circle, if it is not a perfect circle then, adjust the screen resolution again until you see a perfect circle. I suggest you start at the highest resolution that suits you and work down.
Mar 21, 2010 | Compaq Computers & Internet
When I go to view there is no zoom in this place. My home page is to wide for the monotor screen. how can I narrow it to where it is 100 per cent.
go to settings on your desktop Right click anywhere and the go to properties then go to settings increase the screen resolution to 1024x768 things will get smaller. set the color quality to highest (32bit). then adjust your monitor. in menue set to fit window.
Hope this helps
Nov 19, 2009 | Computers & Internet
2005 Nissan Sentra 1.8S, with AC - how to replace belts?
first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
Aug 23, 2009 | 2005 Nissan Sentra
Problem in monitor the screen doesnot get full wide of it by control panel
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Nov 10, 2007 | Hansol 730E 17" CRT Monitor
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
