Question about Sharp Office Equipment & Supplies
How do i install a toner in my sharp m450n i cant work it out
    Problem Solver:
  • 8 Answers
The link below is to the support page at sharpusa.com. This is where you can download the user manual for your MF Printer. There is a small blurb on page 1-25 that references adding toner but then tells you to reference the "Supply Replacement Method" document.
http://www.sharpusa.com/products/TypeManuals/0,1083,18,00.html
Your best bet is to email the customer support team at Sharp and request the "Supply Replacement Method" document that details replacing toner cartridges. You can request that here: http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
Hope this helps,
Genie-Us IT
Posted on Jun 26, 2008
  • 148 Answers
You can go here: http://www.sharpusa.com/files/cop_man_ARM355_455N.pdf
Download the operation manual and on page 2-15 you will find the instruction with illustrations on how to add toner for that machine.
Hope that helps...
Lbcoaster
2 Suggested Answers
  • 4 Answers
SOURCE: Sharp MX-M450N getting F2-00 error
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Posted on Aug 31, 2010
Toner sensor reset
Try to install another new toner cartridge, you may have a defective toner????
Jan 13, 2014 | Sharp AR-M450N Copier
How can l solve Error Code l4 02 in Sharp AR-M451N Copier
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Nov 25, 2013 | Sharp AR-M450N Copier
Hi ! My names JEAN. I own a second hand Sharp AR-M450N Copier.But since the day I bought it, I've never been able to use it.Its TONER isn't available here in Cameroun- Africa, the drum, the developer are...
Precision Roller sells all of the supplies and most parts for this machine. They also Ship to Africa. At least it is not on their resticted list. I would visit them at www.precisionroller.com and ask them specifically via their live chat screen wether they can for sure ship to you but I beleive they can.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Sharp AR-M450N Copier
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
trouble
Sensor trouble
Check and
remedy
sensor.
Replace the sensor.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
F4-02 Improper Cartridge message on Sharp AR-M450N multi-function Tried everything -- unplugging everything -- turning everything back on then tried #*C* 14 enter 1 enter also tried 15 enter 1...
You may just have a Bad Toner Cartridge... It will happen from time to time..... There is a IC chip on the back of the cartridge, it may be bad or the toner feed screw is bound up... Replace the cartride with a new one..... Also, is it a OEM toner cartridge or a genaric one?
May 04, 2010 | Sharp AR-M450N Copier
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Dec 28, 2009 | Office Equipment & Supplies
Get an user manual for a sharp copier model #AR-M450N
sharp.com should have the manual to down load
Dec 03, 2008 | Sharp AR-M450N Copier
95 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
