Question about Sharp Office Equipment & Supplies
Alternating 4 - h on a sharp al-1540cs copier
  • 148 Answers
To perform the reset for the H4 do the following:
Find the Clear button on the Control Panel.
Find the Auto button.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Then,
Press the [10's] key one time and the [1's] key four times to enter so the number '14' is in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the [Clear] button two times.
The machine should now warm up and come to ready.
If the above steps do not clear the error code You may need to have a tech look at this.
Hope that helps...
Posted on Jun 26, 2008
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Makes a grinding noise near the drum. Copier works, but makes a "gear-grinding" noise near the drum area. Can't tell what's doing it.
Un load the drum unit, check the drum/s gear, is it wear off, if so change it along with the drum's drive gear at machine base, check also the gears of developing unit
Jun 29, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Error code 1 and L flashing alternately
Hello sir; I like you check the scanner unit, the mirrow does move out when you make a copy, you may easy to find out what cause the mirrow not move out.
Jun 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Blinking h then 4
The error H and 4 blinking indicates that, You have a defective fuser unit.
H is for HEATER
You should replace youe heater unit, if your product falls in warranty period, you can avail wrranty..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Apr 10, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Printer drivers for Mac.
Goggle download program for Sharp AL-1540CS. This should take you to a site that will download the program for you. I recently got a new Vista computer and did this to hook up my old printer on it. It worked fine.
Good Luck
Jun 18, 2008 | Sharp AL-1540CS All-In-One Laser Printer
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
