Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
Compatibility of p4m800-M socket and ddr pc266
Can i possibly use my spare ddr pc266 memory on my p4m800 mobo? thanks
Thanks for the info. i think i have to junk it and buy ddr400 just to be safe.
Posted on Jun 27, 2008
  • 58 Answers
The motherboard supports DDR400/333 DDR SDRAM only according to their website. So most likely not..
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
Is P4M800-M7 mobo can support the pc333 sdram memory? Thank you.
Yes, according to the specs that I read the P4M800-M7 (socket 775?) is designed to support pc333.
Only one time I had a problem with an ECS motherboard, I had the correct memory, but the board had a different voltage requirement. Did not cause any issues, other than it didn't work. I don't think that this would be a problem for you though.
Oct 14, 2008 | EliteGroup P4M800-M7 Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Motherboard upgrade
dont mix your pc400 to the pc266.
Feb 16, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Memory chips
You can use PC2100, see below for example http://www.amazon.com/Memory-Upgrade-PC266-PC2100-AA32C12864-PC266/dp/B00009OYBA
Sep 21, 2007 | Intel Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
RAM Support
if it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Jul 30, 2007 | EliteGroup P4VMM2 Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
168 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
