My KINYO-DVD800 player gives and error code no disc when I load my disc to play. What can I do to resolve the problem?
5 Suggested Answers
SOURCE: rca dvd player drc285
I have returned the same dvd player twice and it seems that they all have this defect after a few runs. It's a shame because they can read divx but I'm done with this cheap brand made in very light fragile plastic. I've been told that there is nothing to do with this problem, it's just a bad one.
Sorry
Posted on Feb 02, 2008
SOURCE: Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Posted on May 01, 2008
Beignorant
  • 51 Answers
SOURCE: Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Posted on Apr 02, 2009
  • 107 Answers
SOURCE: Won't load DVD
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Posted on Apr 21, 2009
  • 393 Answers
SOURCE: "Wrong disc" memorex dvd player error
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
Posted on Mar 02, 2010
Vauxhall insignia dvd800
Laser is offline. Needs to be serviced or junked.
Mar 10, 2014 | Car Audio & Video
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
How to fix error 0507 for dvd r325
If this not resolve the problem, you must tes the reset+clock signal for to RESET the microcontroller, unppluged the power cord by 15 minutes, and connect again. If the problem persist you have problem with the sections blocks electronic peripherifical to microcontroller or itself. Go to the repair shop TV for fix it.
remember do the 6 steps befores
God bless you
Jul 21, 2012 | Televison & Video
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
Doesn't seem to see disc. reporst disc error.
It is possible that you have a disc with a format that is not supported by your player. This can happen for many reasons. If your player will play a new standard DVD it is most likely the other disc that is the problem. Every player is different. Some new less expensive players will play almost any thing. A newer better quality player may not play as many formats. Besides the issue of format you can find security issues with either old discs or more likely an older player. Discs that are a problem more often are discs that have been burned copied or down loaded or produced by a company that uses a format that is not as widely used. The last problem is common with work out videos and generic movies / kids programs . You may also check to see if your player can except a software update.
Aug 21, 2009 | Samsung Audio Players & Recorders
Fix Error code 6 on CD player for 2003 Tiburon GT
From Tiburon owners manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
Jan 04, 2009 | 2003 Hyundai Tiburon
Bad Disc
Try using a lens cleaner and see if that resolves the issue. Also see if this error occurs with all discs or just a particular one. If it happens with all discs, then it is a lens problem. If it happens with just a few, then its likely that the disc itself is scratched or defective.
If the lens cleaner does not resolve the issue, then you will have to open the cover. Try using a can of compressed air to clean out the insides. Also, clean the lens itself with some isopropyl alcohol and a cotton swab. If the lens is scratched or dirty, you may have to replace it, in which case, it would be cheaper to simply buy a new player.
May 25, 2008 | Philips DVD 622 DVD Player
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
