Question edited for clarity, FULL 'make model (what it is)'.
Ascertaining the date is in the link and done from Serial Number. Tonnage is only on AC Units, furnaces are graded by BTU (British Thermal Units), and that is also on the serial label.
That model number is for an air handler (indoor unit) and not associated with tonnage. Air handlers are more often rated according to CFM and auxiliary heat.
In order to get the tonnage you would need to look at the model number of the outdoor unit (likely a heat pump). Typically tonnage is expressed in 1000s of BTU/hr, i.e. 24 = 2.0, 30 = 2.5, 36 = 3.0, etc.
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Get Model number of compressor (all compressors have a tag with a model number on them), and call a dealer who can tell you the tonnage of the compressor which will be the same as the unit.
Note: Write down all the numbers on the compressor to be sure you have the proper info that the dealer will need. Also, you can probably do a 'search' on the computer with the model number of the compressor to find the tonnage.
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Usually the date plate is mounted on the A/C unit near the power connection. Sometimes you have to remove the access plate for the electrical connection to view the data plate and othe information about the unit.
Just be sure you kill the power to the A/C before you go opening up the access cover to prevent getting bit by the 220V-AC voltage inside!
In almost every case, most manufacturers put the tonnage in the model number. Look for something that is divisible by either 6 or 12. Something like, 24, 30, 36, and so on. Cfm has to match the tonnage. Usually in the neighborhood of 450 cfm per 12,000 btu's of cooling for the inside of the structure.
The blower size is selected based on the details of your home. The size of the motor must match the tonnage of the A/C. The tonnage of the A/C will be determined with a heat gain/loss calculation.I believe there are at least 2 options for this furnace 3 Ton, and 4Ton.
