My projection tv trys to come on but won't you push the button and the power on light comes on but goes off comes back on then goes back off 3 to 4 times then goes off for good started few days ago but if i keep pushing the button it would come on but now nothing
  • 8 more comments
  • klloyd99 Jun 26, 2008
    i think it blinks 3 times
    ok i'm at work now i'll get that info when i get home Thanks..
  • klloyd99 Jun 27, 2008
    the model # is D52w19 if i just push the power button it goes on and off 3 times if you hold it will blink 1 time pause then blink 9 times and as long as i hold it it will blink the same pattern 1 then 9.
    i cant the site to come up
    this says its for model# D52w12 mine is D52w19 will it still work?
  • phildirt2000 Jul 23, 2008
    MY RCA MODEL D52W20 HAS SAME PROBLEM WILL NOT TURN ON. MY POWER BUTTON BLINKS 1 AND THEN 9 TIMES WHEN HELD IN. IS YOUR FIX THE SAM FOR 9 BLINKS AS FOR THE 3 BLINKS OR IS THIS ANOTHER PROBLEM?
  • klloyd99 Jul 27, 2008
    i got part but can't get tech support on site.
    got part, but can't find tech support on site.
    does this part have to be soldered back in?
    i contacted them through the "contact us" is that right?
  • 8,617 Answers
I need the model number of your set. And can you count exactly how many blinks the power light blinks when you press power? Please respond to this same post so all comunication will be available for each response.
Posted on Jun 26, 2008
  • 6 more comments
  • Sonny Berry
    Sonny Berry Jun 26, 2008
    I still need the model number for instance to help you for instance a RCA D52W series TV 3 blinks is flyback and panasonic 3 blinks is convergence . So if you post the model number of the set I can tell you whats wrong , which part yopu need and even where you can get the replacement part with free instalation instructions.
  • Sonny Berry
    youre welcome just keep responding to this same post. Thanks
  • Sonny Berry
    Sonny Berry Jun 27, 2008
    you need to replace the flyback.Its a easy and inexspensive repair, you van get a replacement flyback at the following link for less than 50.00 and they provide free tech support to help you install it. you need flyback 259296. here is the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    they usually do site maintanance in the evenings I have that problem once in a while it says busy but try again in a few minutes and you will get through.
  • Sonny Berry
    yes they are both ITC222 chassis that will fit D52w12 through D52W59
  • Sonny Berry
    Sonny Berry Jul 27, 2008
    Leave them a email and they set you up with a account through Gmail for your instant messageing tech support.
  • Sonny Berry
    Yes the old one needs to be de-solderd and the new one solderd back in, but its very easy there is no precise soldering invloved and nothing real close quarters like ICs or what not,. the entire de-soldering and resoldering takes about 20 minutes after the board is removed. That site will talk you through it step by step with instant messsageing
  • Sonny Berry
    They should contact you back shortly with instructions on how to get support.
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
When you push the power button, the fan comes on..If you then push the lamp button, the lamp lights up then immediately goes out and the temperature indicator light goes out and the power button blinks..
it sounds like you need a new lamp, this lamps are rated 6000-8000 life hours a life span of 2-3 years of use most of the time the problem comes from the lamp in this TV sets this is the lamp you need
http://cgi.ebay.com/ORIGINAL-HITACHI-UX21511-DLP-LAMP-REPLACEMENT-BULB-OEM-/120607006394?pt=LH_DefaultDomain_0&hash=item1c14bcdeba
Sep 20, 2010 | Hitachi 60V500 60" Rear Projection...
The power keeps recyling
is it flashing green? most likely the bulb.
Amazon has them for around 150
SONY XL-2400 replacement bulb
Mar 02, 2009 | Sony KDF46E2000 46" Projection HDTV
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Electro Med Services...
