Question about Yamaha Audio Players & Recorders
I recently acquired a Yamaha O1V digital mixer and when I power it on the LCD display lights up but the screen is blank. Also none of the buttons on the board are non-responsive. I attempted to do a factory reset as suggested in the operations manual to no avail. I did not purchase this item it was given to me. Any clue as to what would cause this issue?
  • stevejai2002 Jun 29, 2008
    It was the 5amp fuse on the power supply that powered the logic circuitry. Works like a charm now. Thanks your help was invaluable
    Brigadier General:
  • 6,966 Answers
To my knowledge most LCD display of this type would (at power up) indicate a systems check (all display shown) and revert to default display soon as diagnostics are finished. Since you have done a reset (revert to factory defaults) and yet no display is indicative of a major problem in the logic circuitry. I would discount any power supply issue since as you posted "...display lights..." except perhaps the +5VDC rail (which supplies the logic circuitry). The are some instances of other versions of a possibly failed memory battery.
Since diagnosis and repairs of this nature would require familiarity with electronic circuitry and components, use of a DVM and possibly a soldering iron and access to a service manual or at the very least a schematic diagram with voltage readings, it may be to your advantage to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 27, 2008
  • 1,512 Answers
Hi
Something has happened to it.I would be checking the internals for power supply problems,cracked PCB's, loose connectors
  • Graeme Ross
    Graeme Ross Jun 27, 2008
    If you cannot see anything physically wrong with it, a trip to a Yamaha repair guy may shed some light onto it for you. But it dont sound good.
The sound works, but why is there no display on the monitor?
Hi Kelly Forshey
I´m really sorry that the Baby monitor does not work as it should, but you can contact our tech support department For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames to this phone #: 1-888-331-3383 from Mon-Fri 7:00 am-7:00pm CST or visit us here https://motorola-global-portal.custhelp.com/app/mcp/service/ and Chat Online with one of our representatives who will assist you the with issue that your having with your device or send us an email.
We´ll be more than glad to help you
Best Regards
Maya
Motorola Support Team Motorola Support Find Answers Motorola Mobility Inc
Jul 09, 2015 | Motorola Mobility MBP33 Video Baby Monitor...
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
The digital display will not come on.
You need to replace pilot light, small bulb behined an lcd display.
Nov 30, 2009 | Yamaha RX-770
Yamaha htr 5550 stereo receiver blank display. It
I would suggest a quick resoldering of the flatcable connectors, both on the display board as well as on the main board. That should fix the problem.
Oct 20, 2009 | Audio Players & Recorders
The front Display of my RX-V661 is not readable. after a night of being turned off, it lights up for a short period before going off (it does not display anything at all) I tried resetting it, but since i...
There's a common problem with the Rx-V661 where a capacitor blows and then the display on the unit no longer works. It will start to display when you first turn it on, but fade out right away. This is because of a blown capacitor and a known issue for the Rx-V661.
Oct 08, 2009 | Yamaha RX-V661 Receiver
Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
Yamaha front panel display dim
Yamaha RX-V661 LCD / Front panel.
Symptom: when you first turn it
on, you can see a VERY little light but after 5 sec, you cannot see it anymore
or for most of us, we started using a flash light. Here is the summary of the solution and I know that it works
because I fixed it today 3/16/2011, 30 minutes ago.
As many pointed out that there is a
"light" 12v - 14v in the back but there is NONE. How do I know? I listened and searched and
there are NONE. The whole LCD in the front is air seal like a light bulb so it
is a light bulb already. Also, you might
see a little burn/gray smoke on the left hand side, don't worry about it
because if the light comes on, it stills work but not enough power. If the LCD
is broken, please don't try by the part and replace it because by the time you
read this, the parts and labor cost as much as buying a new one (on eBay and
not Best Buy).
Problem: in the middle of the unit near the back near the "surround
sound back", there are 3 capacitor rated at (2 units) 35v 220uf 85'C and
(1 unit) 50v 220uf 85'C. What Yamaha did wrong, base on my guess is that they
put the 85'C too close to the heat sink.
The heat causes the capacitor to slowly blown that is why you still get
your power to the LCD but not enough.
Solution: remove the top, unscrew EVERYTHING in the back and there are about 20 ~ good luck. For
those that don't have good memory, please take a picture. There are many plugs inside
that you need to unplug before you can remove 1st layer (audio/ video input)
2nd player (HDMI and Optical input), the last layer you will see 3 capacitors that
are kind of "blown" up (google "bad capacitors" pictures or
video). Remove them then replace them, which you can Google this on tube and
they should teach you how. It was very easy for me but then again, please don't
try to do it if you cannot even change your car oil or build a computer because
I believe that is the difficulty level.
solder iron: $9-$20 get it on eBay or radio
shack
(2 units) 35v 220uf 105'C and (1
unit) 50v 220uf 105'C or what I got was (3 units) 50v 220uf 105'C
I keep the 220uf the same to be
safe but increase the voltage and heat to increase the life of the capacitors.
Good luck everyone,
May 29, 2009 | Yamaha RX-V661 Receiver
No display lights
It will be a button on the remote.
Best option is to go through the manual looking at what all the buttons do - one will be a blank the display option to "save power" or to "turn off as many unnecessary electronics as possible so you get as clean a sound as possible".
A bit of a wank feature really, but they build them into it...
Apr 26, 2009 | Yamaha RX-V661 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
240 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
