Question about Carrier Heating & Cooling
I have a carrier zonepack ducted reverse cycle split airconditioneer, model no: 38ZQ024. There is a honeywell T6060B1104 non programmable thermostat with it. I would like to replace it with programmable one. Which one would you recommend?
  • 15 Answers
SOURCE: Carrier Performance Edge Programmable Thermostat
Are you a qualified refridgerator mechanic with an eletrical liscence? If not get someone who is because doing it yourself will not only void the warranty of the unit but will also void your house and contense insurance in the event of a fire.
Posted on Mar 16, 2008
SOURCE: manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Posted on Sep 06, 2008
pierre1811
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
SOURCE: Honeywell CM67ng thermostat not working.
The cm67ng has a feature which attempts to get the temperature to the desired point before the actual time you set. In reality this "feature" just makes the device turn on and off randomly in a really bemusing fashion. You can turn this off with the following:
1, Set timer mode to "OFF"
2, Hold down "Info i" and press "prog 3" and "prog 4" together. Display Should show a spanner in the left hand corner.
3, press "prog 2"
4, repeated press "clock +" till the characters in the display after the colon read "OP" (the number before the colon seems to vary with model).
5, Press the "temp down" button. The 1 in the right hand of the display should become a 0.
6, Press the "info i" button to save your changes.
7, Switch the mode back to auto, the timer should now behave normally.
You should note that a number of other parameters can be changed in this service mode. Some of which could probably do bad things to your central heating system if set incorrectly.. So this is at your own risk! Either way it's best to read the installation manual before attempting to change anything:
http://content.honeywell.com/UK/homes/Technical/CM/cm67i.pdf
Posted on Nov 10, 2009
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Why does fan not cycle off on heat cycle for TH5220D1029 thermostat
1) normally you must to exchange by new batteries with the same types alkalines FULL charges.
1a) see if there are some wires loose and tight it
2) reset and program it again , follow the instr. manual if you do not have download from Honeywell from section support give the number, model and do it.go to http://yourhome.honeywell.com/home/
God bless you
Oct 08, 2012 | Honeywell Th5220d1029 Non-programmable...
Removed honeywell thermostat from new home to install a new honeywell programmable thermostat. Couldnt get the new one to work so reinstalled the old one and it wont work. Checked breaker already, cant...
Do you have a model number for the new and old thermostat? Do you have a split system? This means you have a heater in the house and a condensing unit somewhere outside of the house. Let me know if you have a packaged unit or a split system and we can go from there. I might just be a blown fuse on you board, but I need to know what you have so we can start to trace things out.
May 11, 2010 | Honeywell Programmable Thermostat Heater
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
Carrier programmable thermostat flashes E3
manufacturers put their name on lots of other peoples stats. Honeywell has a very good help line and an online service. Need to know whose thermostat white- rogers, Or honeywell Or Model number
Aug 20, 2009 | Carrier 38CKC060 Air Conditioner
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
161 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
