Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmore Trio Bottom Freezer Refrigerator
Thank you in advance for any help you may have. My freezer is very cold but there does not seem to be any air circulating into the refrigerator which is very warm. The freezer got noticeably colder recently (vodka froze) at which point we noticed the warm refrigerator. There is also a rather loud hum at this time.
  • 828 Answers
Loud hum could also be from the air circulating fan in the freezer compartment.
Posted on Jun 28, 2008
Why is Refrigerator warm, Freezer is cold
This seems to be a common problem with bottom freezers.
Usually there is ice buildup in the cold air passage from the freezer to the refrigerator. There are videos on Youtube that will help.
Link below.
bottom freezer refrigerator not cooling YouTube
Jul 31, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore model 596 72913200 freezer works but fridge not getting cold
This will be an air flow problem from the damper failing. Usually what happens is, the air vent is not allowing air to pass at the damper due to the motor not opening and allowing the cold air to pass into the refrigerator side. A good way to check it is, to feel the amount of air coming out of the vent between the freezer and the refrigerator. If the air flow seems slow, or no air at all, replace the damper to restore air flow to the refrigerator.Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The top frig is not cold at all , as if the motor stop or something
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The refrigerator and freezer are not cooling the freezer reads 12 and the refrigerator is 42
I am a celcius man myself. So I assume you are talking about degrees fahrenheit?
Basically you are not getting the correct temperatures in the refrigerator or freezer. this could be due to
# Condenser fan not working (condenser is the outside of the fridge that gets hot)
# condenser blocked or dirty
# Poor air flow over the condenser
$ evaporator fan not working (this circulates cold air inside the fridge)
$ The ducting for the cold air is blocked
$ the themostat is faulty
& Compressor has burnt valves and cannot pump properly
* the fridge is loosing refrigerant
Mar 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerator is not cold. Freezer is fine.
heatman101
Oct 23, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
143 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
