I cant change my screen resolution correctly the screen is too big i tried installing drivers for my video and it wont let me install i found a screen that gave my options but when it changes it how i want it the screen is mess up and the color is choppy dont know what to do
  • 63 Answers
Hi Dubz,
It sounds to me that you might be setting the resolution to something that your monitor cannot handle. Check your monitor manual for the supported resolutions and try one of them.
If you dont have the manual try 800 x 600 or 1024 x 768 as most monitor support those resolutions.
Regards
Andy
Posted on Jun 26, 2008
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
Cant change screen resoloution
If you cannot change the display resolution and the video driver is generic VGA then the correct video driver needs to be installed.
You can download the video driver from the laptop manufacturer's WEB site.
I cannot give you the link to download this driver because you did not provide then make and model of your laptop.
Mar 03, 2013 | Computers & Internet
Cant get a full screen
You may need to change the screen resolution.
Go to Control Panel - Display - Settings tab - in Screen resolution, move the slider to 1024 x 768 and Apply.
If you cannot increase the screen resolution then most likely the incorrect video driver has been installed. Install the correct video driver and you will be able to increase the screen resolution.
Apr 02, 2012 | Computers & Internet
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
To improve the colour bits
It is possible that you do not have the correct drivers installed/available for the graphics card, try using the drivers i have found on the intel website, the link below
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=6107&ProdId=1065&lang=eng
Jun 26, 2010 | Intel D845GVSR Motherboard
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
Can not config the size
if the screen is big, try to change the screen resolution, or install the video driver from the manufacturer drivers disk that you would have,,,
refer to help and support in your computer for guidance on how to reduce the screen resolution,,,
click on start >>>> help and support, then on the search box type how to change the screen resolution
2. how to install the video driver
you will have step by step instructions, and you could get it resolved,
follow those steps clearly
Feb 14, 2009 | Acer AL1912 19" LCD Monitor
Screen Resolution Too Big
you need to reinstall your video driver found here
Jul 27, 2008 | Dell Latitude D400 Notebook
Resolution automatically changed on startup
If your monitor is actually the Zenith 17" HDTV, the native resolution is 1366x768. You may be able to "force" this resolution using powerstrip. It is freeware and you can download it here.
Jul 13, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
