Lexmark T520 Laser Printer Logo
Anonymous Posted on Jun 26, 2008
Lex T520 BUSY PCL
I have a Lex T520 that will not print and only displays Busy PCL on the display. In order for me to print, i have to power cycle it everytime. Help me please!
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Jul 23, 2008
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286542
Points
2705
Check that the RAM is not bad. You can remove it temporarily and the printer should operate on the 8MB built into the main board.
Maximum Memory 264MB Memory Slots 2 Slots non-removable base memory 8MB
Display reads call pilot busy and I can not check messages
This means that all extensions to the call pilot are in use or the call Pilot is locked up. Try again later or power cycle the Call Pilot if it is an external unit.
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Appare scritta busy nel mirino, non si accende display grande
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Client reports display shows BUSY, but never prints. I ran the Demo Page OK. Also, 5-page print tests on USB and parallel without issue. There's no add on memory. Could the Controller Board being failing...
the logic board could cause this if the nvram is messed up. how ever i have found this to be caused by the engine board about 98% of the time. change the engiine board and your problem will go away
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
1helpful
Will not print fax's
1. Unplug the fax machine from the power outlet.
2. Press and hold the "Stop/Exit" key, then plug the power cord back into the power outlet.
3. Continue to hold the "Stop/Exit" key for 5 seconds. The display will return to date and time.
4. If the display does not return to date and time, please repeat the process to make sure the procedure was completed correctly.
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
How to turn off the busy light on vivitar cam 5399
the busy light is also your power on light its a bad name for it just press and hold the power button until Bye-Bye is displayed on the screen.
5helpful
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
4helpful
IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
