Question about Kenmore TRIO 77314 Side by Side Bottom Freezer French Door Refrigerator
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
Kenmore Trio french door 25 cubic foot fridge with external ice and water dispenser. Fridge is just over 1 yr old (and past warranty) and the touch control pad is flashing continuously with the ice door continually opening and closing. Water and ice dispenser are not working but fridge and freezer are fine. Service rep came out and thinks it may be the control pad cicuit board as he could not get it to let him in to the programming mode (pressing door alarm button and freezer temp control at same time for 3 seconds). I am waiting to find out the price of the circuit board. Any ideas if this sounds correct?
  • wolseley Jun 26, 2008
    thanks for the prompt commentary - can't find the exact circuit board on the site but at least I now have an idea of what it's going to cost.
    Genius:
  • 1,036 Answers
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Posted on Jun 26, 2008
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Ice flap continues to open and shut, then it sits for a while crazy blinking touch pad.
I would be looking at a new control board. Sometimes you don't know whaTthere going to do and when there going to do it when they are on there way out. The board will tell the unit the temp inside and tell the compresser to turn on or off and to make ice or not. It is the heart and if it is faulty then nothing works properley
Sep 06, 2012 | Maytag MFD2561HE Stainless Steel Bottom...
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
We have a Kenmore Elite 79577554600 Refrigerator. The temperature display is freaking out. The numbers keep changing, lights flashing on and off, temperature counting down from 44.
It is running in "store-demo" mode. Fancy light-show, and the compressor turns off (bad!)
Hold down the right-most two buttons (Ice and refrigerator temp) for about 5 seconds. I think the right-door needs to be open for this to work, but not sure.
This will activate the fridge once again.
Dec 24, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore TRIO 77314 Side by Side Bottom Freezer French Door Refrigerator Logo
476 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
