Question about Carrier 36KCARMS Air Conditioner
Central Air not cooling properly
Our daughter and son-in-law have a Carrier air conditioner. They can't seem to get the air conditioner to cool down the house. The main 'black' pipe coming from the air conditioner to the inside furnace also has a small copper tube running along side of it. The copper tube is very warm, almost hot to the touch. The same copper tube on my air conditioner is room temperature, not warm at all.
Could the problem be with this tubing? What fluid runs through this copper tubing?
Any advice would be appreciated.
email - idockter@yahoo.com
  • idockter Jun 26, 2008
    Thank you for the prompt reply. We'll take a look at the Coil.
  • Anonymous Mar 17, 2014
    air conditioner presure line copper stolen
    Novelist:
    Champion:
  • 230 Answers
This tubbing carries the refrigerant. The small line is flowing to their inside air handler. If the line is hot it is an indication that the outside unit is not able to release the heat. The most common reason is that the coil (looks like a car radiator) is dirty or plugged. This can be cleaned with a brush or sometimes a garden hose. They do make acid type cleaners for doing this, but the use of the acids are restricted in some areas.
By the way the other black pipe should have a larger copper line behind the black insulation. That line should be cold and sweaty like a nice glass of ice tea:)
Posted on Jun 26, 2008
AC duct temp range.
you need to take the temp of whats coming out of the plenum and the temp at the return and subtract them and you should have a difference of 17-20 degrees, that will tell if you are cooling properly,
Aug 03, 2014 | Carrier Heating & Cooling
Carrier 38CKC front on unit
I had a similar issue, albeit a different brand of air condenser, and it turned out to be a relay capacitor that controlled the valve I suspect you are speaking of. However, I did have both the valve and capacitor replaced...just to be safe.
Apr 30, 2012 | Carrier 38CKC024 Air Conditioner
No manual for a cool 438656
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
domecrel.com/recent-carrier-xhb123d-xy-series-heatcool-air-conditioner/
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
Jan 05, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
What size is a Rudd UAKA-048-JAZ?
it is a 4 ton and should cool your home if it is working properly
Jun 15, 2010 | Ruud Central System Air Conditioner
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air conditioner will not turn on at all.
I understand this to be a heat pump. Check your thermostat settings, and the filters. And make sure a breaker isn't tripped.
May 21, 2009 | Carrier Heating & Cooling
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
350 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
