Question about Freezers
Whirlpool Easytronic Hi Any idea why the temperature has dropped on my freezer? The electric is supplied ok but not sure I can hear the motor running any more. Is this simple to fix or do I need a new freezer? Would be ever so grateful for a reply. Thank you .... Sue
  • Anonymous Aug 11, 2008
    temp dropped difficult to get up to normal -18, feached -17today after 18 hours of continual running
    temp
Trouble reaching -18 sudden drop yesterday to-6 took till 6am this morning to reach -17?as to why
Posted on Aug 11, 2008
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
Unsure how the temperature dial goes. Is it l. or r. for colder?
Hi Normally temperature dial has at left maximum temperature while right is minimum temperature.
You can feel ( hear ) actually the sound of motor/compressor when it is run. Running motor will produce low temperature. By this you can decide where the set point should be made
Sep 09, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Hotpoint Whirlpool upright freezer. The lights all work but the temperature is slowly dropping - now only -7 C and the freezer is silent. Before this the temp lights kept flashing and vibrating (quite...
Problem has sorted itself out. We removed and gave away quite a lot of food from the freezer and cleared away some ice that had accumulated on the temperature sensor. When we checked this morning the temperature had returned to -24 C so we don't need to go in search of a new freezer today, thank goodness!
Dec 27, 2009 | Whirlpool Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Motor makes noise and not sure if it is using a lot of electricity
it's normal. because due to running of compressor and motor this type of sound is developed...............have a nice day :-)
May 15, 2009 | Frigidaire 20 cu. ft. / 566 liter Chest...
Whirlpool ARC 5070
Temperature control may have failed. Thermostat causes compressor to cycle on and off with temperature in the refrigerator section. If the compressor is not trying to run and is cold to the touch no power is getting to it. compressor is located in back on the bottom.
Additionally the defrost timer may have stopped working while in the defrost position. Locate the timer and rotate the clutch head screw clockwise a small amount and if the compressor starts and runs replace the timer.
Jun 17, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezers Logo
289 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
