Question about Whirlpool LGR8648 Gas Dryer
Gas dryer lgr 8648
Dryer starts no problem heat seems good then heat stops and it blows cool air
  • 1 more comment
  • Art VanDelay Jun 28, 2008
    I am seeing the same problem. Model LGR8648LW0 Dryer heats for some time and I feel the hot clothes inside the dryer. I also feel the hot, wet air at the discharge outside the house. After some time, perhaps 10 minutes, the heat stops and I can sometimes smell gas outside the house and inside the dryer.
    I stop the dryer and later start it and the cycle repeats; dryer appears to work, then cools and smells of gas. I took the back of the dryer off and watched the flame to see if I could see why it was not continuing to heat. I noticed the flame seemed weak and was "flashy" and yellow at times. I think the flame should be a strong blue flame but I don't know for sure. While I was watching the flame, my dad opened the door leading to the garage and the flame immediately went out. We were able to repeat this every time this particular door was opened and sometimes when other exterior doors were opened. So I believe my problem is with the dryer and it has become very sensitive to the air flow/pressure in the house. I will look further into this dryer today.
  • FORDCHSPCAP Jan 07, 2009
    I HAVE THE SAME PROBLEM THE BURNER STAYS ON FOR ABOUT 10 MIN THEN GOES OUT. CHECK AIR FLOW AND IS GOOD. CHANGE THERMAL FUSE AND GAS VALVE COILS. STILL DOES THE SAME THING.
  • G-Co Jan 19, 2009
    I have the same problem. How do you access the gas valve coils?
Found the coils. Had to pop off the entire front panel. They were then easily reachable.
Posted on Jan 19, 2009
Back in June I replaced the gas valve coils and that fixed the problem. It appears that when the coils are begining to fail, they'll work only when they are cold. After the dryer is up to full temperature the coils will not open the valve when more heat is needed...at least not until the dryer cools down.
I had this same problem with my furnace flame sensor. It failed in a way that it would only work when it was completely cooled down. Troubleshooting revealed that the furnace was failing at the 5 second "wait for flame sense". At that point the flame would go out and I could not restart it until everything cooled down. Thanks for all the help on this.
Posted on Jan 08, 2009
I HAD THE SAME PROBLEM. I CHANGED THE GAS VALVE COILS AND IT WORKED FINE.
Posted on Jan 07, 2009
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • jayjp Jul 10, 2011
    its a gas dryer meathead not electric.
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Dryer stopped heating only blows cool air
you have to open the back off dryer,the r two thermostats. they are round held by 2 small screws. high heat- low heat. use volt meter to see which one is bad. if u put volt meter on wires,it will let you know which is bad. 30 to 35 a pc.
Mar 17, 2013 | Dryers
My dryer stopped heating/drying. no heat is coming out. It went from drying 90% to nothing in 3 loads. blower is blowing..only cool air.
Upon starting you will hear a clicking noise which is the spark ignitor. If heard the two coils on the gas valve are the problem
Feb 02, 2011 | Amana NDG8805A Gas Dryer
Dryer Model LGR 8620PW0. Dryer initially heats up for three minutes, then heat shuts down. Glow coil comes back on, but no gas ignition. Glow coil continues to do this. Thermal fuse is good. Limits are...
try clearing out the exhaust duct that runs from the back of the dryer to the outside of the house. If this is clogged then this will limit air flow therefore by extinguishing you fire. An easy test to figure this out would be to remove the hose from the back of the dryer and see if you get the same results. If you get the same results try checking all the traps for lint and debris.
Jun 15, 2010 | Dryers
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Dryer heats for 5 minutes then only blows cool air.
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 17, 2009 | Kenmore 800 7982 Dryer
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool LGR8648 Gas Dryer Logo
601 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
