Question about Vapor 3000 Steam Vacuum
Steam sparging line attached to downcomers on HRSG
A 2" sparging steam line is connected to a set of 24" Downcomer lines just before they enter into the Evaporator of a HRSG unit. Could you explain what the purpose of this line is in the operation of one of these units?
The reason for this is to keep the HRSG warm to reduce fuel costs. Due to the price of Nat Gas, it is adventageous to supply sparging steam to keep the HRSG warm so that when the Comb Turbine is called upon to start the HRSG metal temperature will be greater than ambient temperature.
Posted on Sep 11, 2008
Its used fro pre-heating
Posted on Aug 30, 2008
My simple shark steam only cleaner will not steam although the water gets hot
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. One problem might be that the hole the steam comes out of is clogged. To remedy this, take a Q-tip and insert it into the steam hole. Be sure to use a pair of pliers to insert the Q-tip just incase steam does come out. You do not want to get burned to the ensuing steam. If clearing the steam hole does not work try creating a solution of water and vinegar to flush through your steam mop. The vinegar should be able to break-down any substances preventing your mop from building steam.
Attached is a video showing you how to try each of these solutions:
https://www.youtube.com/watch?v=Vz8OvV30sHM
You can purchase direct your replacement shark steam mop pads from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=shark+steam+mop
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark 2-in-1 Vac Then Steam
Steam frame and pad
must be attached to the cleaning unit
in order to use the steam function
manual > http://www.sharkclean.com/manual/MV2010_11_IB_ENG_110103.pdf
Apr 15, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
It doesn't heat. the light is on and it steamed once then quit.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 14, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam mop will not steam. the light comes on and it seems to heat up, but no steam comes out
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
My Shark steam cleaner just stopped working - doesn't make steam anymore. Is there a way to fix it.
I have the same problem - just heard from the support tech to soak the "device" in 1/2 vinegar and 1/2 water. Read on line a customer used vinegar in the device itself, heated it up until it made steam, then emptied it and used distilled water and it was fine. I haven't tried it yet, so we'll see if either solution works . . .
Mar 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Help with steam cleaner
DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Jun 25, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vapor 3000 Steam Vacuum Logo
1,052 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
