Question about Canon PowerShot A710 IS Digital Camera
Fishbowl effect in my image
Hi, I am trying to take pictures of old documents. The librarians recommend this as a safer alternative to scanning or xeroxing them. When I do so with my Canon A710, though, I get a fishbowl effect. The middle of the image is bowed out and the tops and bottoms are pulled in. I am seeking a faithful, square, reproduction. I've been unsuccessful with the users manual when trying to change a setting or fix the set up.
Any ideas?
Ben
  • Canon Master
  • 4,738 Answers
Consider moving the camera further from the document, and then using the zoom (with a tripod) to close in on the document. You may also need to use a "book holder" with this technique. The A710 also has many manual features that you can tweek. Consider using manual focus to ensure sharpness in the image of the document. Also try varying Shutter and Aperture priority (Tv and Av) settings. Recommend first doing this at home to find what works best before going to the library.
Posted on Jun 28, 2008
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Whenever I scan a picture, It's blurry. Canon Mx410
I had the same problem.
My DPI setting was at 25.
I upped it to 600 and the document scanned perfectly.
Jun 04, 2013 | Canon Pixma MX410 All-In-One Printer
How to change scanning from picture to pdf
once you have scanned the picture and saved it . right click on the picture icon. click edit. it should take you into a editing tool like paint . then click file . save as and then the bottom option you can change it to save as a pdf or png or jif, anything your heart desires
May 05, 2011 | Computers & Internet
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    How can I email a scanned document or picture to myself?
    just attach the scanned documents and sent it to your email id
    Nov 14, 2010 | HP OfficeJet J4580 All-In-One Laser...
    How do I scan a picture and email it?
    Hi
    You can start a scan from your computer or from your HP OfficeJet.
    to scan an original from your Windows computer
    1 Load your original either on the glass or in the automatic document feeder
    (ADF).
    2 Press Start Scan.
    A scan of the original appears in the HP Preview window.
    3 In the HP Preview, you can edit the scanned image. When you have
    finished, click Accept.
    For more information about making changes to an image during the
    preview, see adjust an image during the preview in scan pictures and
    documents in the HP Photo & Imaging Help for more information.
    The HP OfficeJet does a final scan of the original and sends the image to
    the HP Photo & Imaging Gallery.
    If i helped you pls vote me
    Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
    I have a Dell All-In-One PictBridge Photo 924. I
    Open Dell All-in-one center, keep the picture on the Scanner bed and click on scan and choose a location to save the picture once the scan is completed and the preview is visible. Alternatively, a simpler way to do this is to Open MSPaint, click on File and click on Import from Camera or Scanner. Choose the kind of picture you want to scan and confirm scan. Try experimenting with options to experience scanning effects and image quality.
    Good Luck!
    -Abhishek
    Nov 03, 2009 | Dell 924 All-in-One InkJet Printer
    How to scan documents then email them
    To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
    If this is already done then :-
    1] Put the document that you want to scan in the scanner,
    2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
    3]Switch on the printer (if it's on only then proceed to next step)
    4]You will see your scanner icon (if necessary refresh the screen)
    5]Open it and click "next"
    6] (OPTIONAL) Select scan image type.
    7]Click "next".
    8]Choose a place to save your image.(default is my pictures)
    9]Click "next"
    10]and now image scan starts, at last click on finished.
    11]Now open your e-mail account, choose "compose mail" fill in the details
    12]now select "browse" (for gmail) or select upload file
    13]select the address of the image where you saved it (default my pictures)
    14]click ok.(you can only upload 1 file at a time)
    15]send the mail. !!
    16]Thus, you can send image by scanning like as stated above .
    Jan 07, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    I press scan it it wont scan my picture.
    1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
    2. Close the lid
    Scanning a text document
    1. Load the original.
    2. From the HP Director , click Scan Document .
    3. From the HP Scanning dialog box, select the desired options and Scan to destination.
    4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
    5. Click Scan . The document will open in the selected Scan to destination.
    Scanning a picture
    2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
    3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
    Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
    Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Canon PowerShot A710 IS Digital Camera Logo
    162 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
