Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Water will not shut off
After starting, the water coming in will not shut off when full
  • 807 Answers
Usually there is a thin pipe from the bottom of the drum to a pressure switch at the top of the machine. As the machine fills the water goes up the pipe from the drum and increases the air pressure in the pipe to a point where it's enough to switch the switch inside. If the pipe gets blocked with washing powder it will not switch off and the machine will keep filling. The pipe is connected to a sort of flat round box with a few wires on it. If you can take the top or back off the machine you should see it and be able to clean the pipe out yourself.
Posted on Jun 26, 2008
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
How to fill the water heater in a 2014 cougar 19rb
I have had two different travel trailers and both of the water shut offs were behind wood panels between the kitchen and the back bedroom
Jul 31, 2014 | Keystone 2014 Cougar Xlite 19RBE
I cleaned out the water from the drip pan, cleaned out the pipe and it started working. Now the drip pan is full again and the furnace is not working
something has to come out the other end. where do you think the water is going? it has got to go outside, if not it will end up in the condensate tray and shut off your unit if you have a float switch.
Sep 03, 2012 | Goodman Heating & Cooling
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
My washer is just running water and not filling up
Check water valve may not be shutting off.
Check water level switch should shut water off when full and starts agitate.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Ice Maker in door of freezer-ref combo.
The ice maker has a float or full detection device that shuts the water off when trays are full. If you are sure this is where the water is coming from, then that's it.
Dec 27, 2007 | Freezers
Power Issue
check the water stored in the aircon unit. if the water is full the unit will shut off with a beep. try to pull the plug and release the water. now try to switch it on
Oct 04, 2007 | Amcor AL10000E Air Conditioner
GE Portable Airconditioner - Model APN10AA Serial # GG509122
Ours was leaking water. After taking the covers off,cleaning it,and draining all the water out, I started getting the same problem with the light coming on every 7 minutes. I actually added some water to the system till it was too full and then drained it out through the plug. The light still came on every 7 minutes until I turned the unit off and then unplugged it for a few minutes. I plugged it back in, turned it on and reset the temperature. It seemed to reset itself and kept running normally. BB
Aug 07, 2007 | GE APN10AA Portable Air Conditioner
Washing Machines Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
