Question about Xerox Phaser 7750GX Laser Printer
Every page I print is faded badly in the center of the page verticaly. I have changed ink for both black and color.
  • Anonymous Oct 30, 2008
    I have the same problem - toner seems to be fine and I've shaken the cartridge to even things out but it's still faded down the center.
  • 23 Answers
Your printer needs new developer and housing in what ever color is effected call service.
Posted on Jul 20, 2009
  • harley07825 Jul 20, 2009
    first try the wand on the door ,remove the waste container and slide it back and forth in the slot under the having problem. a1,a2,a3,a4.
Canon printer mx882 not printing in black
Regarding your recent inquiry about the poor black print quality (Canon PG-225 PGBK ink cartridge) & lack of overall printing performance with your Canon MX882 printer, it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color: 1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
    3.Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
    4.The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
    5.Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
      6.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
      7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon
        8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it's end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical 'head strikes' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
        Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
        For USA store ink refill locations and details on ink refill pricing:
        Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
        Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
        Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
        Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
        -Thank you
Mar 20, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
All ink very faded just changed ink too
You change with the genuine ink or not? Maybe the print head faulty or just the setting problem. Need someone assist you directly to your desktop.
May 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Center
Just remove all the removable parts from your printer including trays, toners, etc.
Shake your print toners so that the toner powder inside is mixed well equally throughout the drum inside.
Replace all the parts back and try printing and may be this should work fine for you.
Please provide back your ratings.
Thanks
Apr 05, 2010 | HP LaserJet 4700 Printer
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Uneven black ink printing
This is the problem of the black developer in the imaging unit. Please contact authorised service center they will change for you.
Best Regards
Nov 14, 2009 | Samsung CLX-2160N All-In-One Printer
Black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Mar 29, 2009 | Kodak ESP 5 Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
May 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Open Questions:
See all Xerox Phaser 7750GX Laser Printer Questions
Xerox Phaser 7750GX Laser Printer Logo
241 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
