Question about GE Spectra JGBP35 Gas Kitchen Range
Gas Odor and Oven Heating
My wife is environmentally sensitve and notices a gas smell in the kitchen from stove usage. In the winter it is particularly a problem with closed windows and the stove is not vented to the outside in any way. Is this a particular issue to this GE Spectra or should we expect this with any gas stove? The side effects of the gas smell is a headache...... I personally do not have the affect, but her mom and sister notice it when they visit.
Also when the stove is cooking something occasionally we will hear a wooshing sound as if the gas is obstructed and trying hard to flow and then it will raise in volulme for 10 seconds and quiet itself again. This will reoccur every 5-10 minutes......quite annoying and initially fearful.
The stove is 15 years old and wondered if this thing is ready for the stove graveyard.
  • 413 Answers
The gas valve may be failing. The 'whooshing sound' you hear may be the gas valve closing too slowly when the oven cycles off or the cavity is filling with gas and igniting when the oven cycles on. The gas you smell may be an indication that the valve is not closing completely. This can be potentially dangerous if the oven fills with gas then ignites. I would not operate the stove any longer and shut off the gas to the stove.
Posted on Jun 26, 2008
Have a maytag Stove Model# mgr5729adw oven stopped working and just before it did smelled gas. ignitor looks to be good no cracks.
Our Maytag MGR5729ADW recently started having a problem. Whenever the oven was turned on gas would flow but did not ignite. My wife thought she was baking, but I walked in the kitchen and smell a heavy gas smell. Bad igniter or not the gas control valve should never open unless there is ignition. Had we turned on the oven and left the house, there would have been a major problem.
After a little more checking I will probably replace the igniter and the gas control valve. The parts are not cheap but neither is a house.
Dec 30, 2012 | Kitchen Ranges
WE SHUT OFF THE GAS TO THIS STOVE SEVERAL WEEKS AGO AND ARE READY TO RELIGHT THE STOVE NOW. WE CAN NOT FIND THE MANUAL AS TO HOW TO DO THAT. WE ARE CONCERNED MAINLY ABOUT THE OVEN AS IT SAYS IT IS A...
You should be able to just open the gas ****. That will supply gas to the gas to the stove. Once you've opened the gas ****, wait about 60 seconds and turn on one of the burners. The electric ignition should work to ignite the gas and you'll have your flame. If you smell a strong odor of gas, DO NOT use the electric ignition until the gas odor diminishes. In other words, when you first smell gas, you can try lighting it. If the smell of gas becomes strong, you DO NOT want to light anything in the area because an accumulation of gas can lead to an explosion. Be very careful.
If this helps, please come back to Fixya and rate my suggestion.
Jun 10, 2011 | Kitchen Ranges
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Smell gas
heatman101
bbv
Jul 30, 2010 | Whirlpool GS445LELS Gas Kitchen Range
I have a kenmore elite slide in range. we notice the smell of gas
There could be a couple things that would cause your symptoms, I will do my best to try and explain each one.
First off I am assuming from your dialog that everything is cooking the same on the top and in the oven, the times are the same the flames on the top burners look or sound no different. If this is the case the repair outside would not have a direct bearing on a 'problem' but it could cause the odor. Here is why...
Natural gas has no odor a chemical called Mercaptan is added to the gas to make a leak easier to detect. The amount of Mercaptan is regulated closely so it all is consumed in the flame. If there is too much you will get an odor from the flame.
The Mercaptan can line the inside of the piping that feeds gas from the regulator to the range. Working on the pipes can break loose some residue that may have a stronger presence of odorant causing you to smell it for some time. It will eventually go away.
The second thing that could cause this odor is if you have done any remodeling in the home, paint fumes, stains, oils many other chemicals can mix with the gas and cause this Mercaptan to not be burned up all the way and create an odor.
I hope this helps
May 21, 2010 | Kenmore Kitchen Ranges
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
When I use my gas range it smells like lighter fluid. Only when it is on, when off the odor goes away. It is a dual stove with electric oven and gas top. It started with one burner and now all 5 of them...
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Nov 14, 2009 | Kenmore Kitchen Ranges
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
GE Spectra JGBP35 Gas Kitchen Range Logo
430 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
