Royal 100nx I have a Royal 100nx cash register, the receipt printer will not feed the advance the paper. I looked inside and can see that the small rubber roller on the advance drive shaft has deteriorated. Is it possible to get a new roller or shaft assembly? Thanks Jeff
    Sergeant:
  • 329 Answers
Royal wil rebuild that printer, It use to cost $125.00 is it work it. Also many cash register dealers have the part. Most printers are an epson printer and parts are available....
Posted on Jun 28, 2008
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Receipt paper does not advance.
You need to replace the feed gear or roller. Or please call a qualified tech.
Mar 10, 2015 | Retail Supplies
Royal 500dx cash register is printing all the characters to far left of receipt, overlapping so they are unreadable. Does not do it all the time.
I think the rack on your printer is worn out, Get a tech to replace it for your or better still replace the whole printer.
Feb 13, 2015 | Royal Cash Register 500dx
How do I change register tape on 500dx electronic cash register
There should be instructions where the paper feeds in. Usually, you follow the rollers with the paper and feed it in. Did you try google.com for you instruction manual?
Nov 17, 2014 | Royal 500DX CASH REGISTER
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Aug 30, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Royal 583 paper not advancing
If it is printing, but not advancing, commonly it is caused by faulty feed roller, gear or motor.
Oct 24, 2013 | Casio Parts Cash Register PC Desktop
Casio cash register model # pcr202
Hi. we don't have that model here, but it sounds like the feed roller has come out. It is common in the little Epson 42 series printers. You will need to get a new feed roller. Some suppliers will only sell you a whole printer - prob around $60-80 US. ring your local dealer and see if one is available.
Mark
Jun 19, 2008 | Casio Parts Cash Register PC Desktop
Changing the paper feeding roller in a cr 110 cash register
hi. You buy the feed assembly (the whole black plastic part that holds the roller) from a dealer, then it clips into the back.
Mark
Apr 11, 2008 | Casio Parts Cash Register PC Desktop
233 people viewed this question
jasbo
jasbo
