Serial cable for Geek Squad 1285AVR UPS
This UPS has both serial and USB ports but came only with a USB cable.
What serial cable do I need? I know that UPSs typically use cables with non-standard pinouts. Can you detail the cable connections I need.
I can't use this with USB. Don't ask.
tom19511
  • 1601 Answers
SOURCE: Home wireless network through my 2wire wireless router/DSL modem.
From what I understand the flash drive is for saving the configuration so you can transfer it to other computers that you may want to put on the network.
Posted on Jan 01, 2008
  • 1027 Answers
SOURCE: UPS noise on my land-line phone
Try using a phone surge supressor independently of the UPS - many outlet strips have them as part of the surge suppressor these days.
Posted on Jun 19, 2008
SOURCE: No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Posted on Jan 06, 2009
jvpacoin
  • 91 Answers
SOURCE: Wanted: Circuit Board Repair APC UPS + other makes.
lol quite tempting. you can send it to me in singapore lol. Hi Andy, i assume theres a lot of UPS tech and Engineers in your area. or UPS service center. Good luck...
Posted on Aug 14, 2009
  • 3600 Answers
SOURCE: Need a cord to connect OLD computer to NEW printer
You can take the cord to Radio Shack and get a 24 pin serial dongle to 9 pin dongle. take a picture of the back of the computer and of the cable if you have and they can find an adapter for you. Thanks for using fix-ya and rate this if it was helpful.
avid101
Posted on Aug 24, 2009
APC Back-UPS Pro 1000: The original smart cable from the UPS to the computer is a serial cable. I'm looking for a serial to usb cable to replace it (the macPro that it will protect does not have a serial...
This older model APC does not support USB and it is inlikely that even if you found a cable that would connect them that the electronics in this unit would play nice with USB. Might be time to consider an upgrade, although these are a great units they just do not have the compatibility with newer computers.
Mar 29, 2011 | APC UPS: BP1000 Back-Ups Pro (UPSAPC08AS)...
Dear experts; We have a HP R3000xr UPS, inetend to install the power management software on a server runs windows server 2008 R2 OS. Installed the power manager server software, the following messages...
Is the cable USB or SERIAL?
make sure serial port IRQ is enabled in BIOS
ALso make sure you are using x64 and not x32 drivers for UPS
ALso try getting a USB cable to connect to your UPS device
Feb 17, 2011 | HP R3000 UPS System
Where is USB port
Many of my APC UPSes do not have a USB port. They either have a serial port or a 6-wire RJ-45 (or close to that size) port with a cable that has a USB jack on the other end.
I hope that this helps.
Mar 24, 2010 | APC Back-UPS RS 800VA UPS System
My ups is back-ups cs 650. How to auto turn on this ups?
yes connect the serial cable came with the ups from serial port to ups there is again one serial port to ups the insert the cd came with ups and install it then it will auto turn offf before battery bown
Mar 02, 2010 | APC Back-UPS Pro 650 UPS System
DL380 cannot see the UPS on COM port with serial cable. I have tried 2 cables. Hyperterm cannot see ups either. HPPM never finds the ups. setiings at 9600 8-N-1 thanks
It is not a standard serial cable. It has different pin-outs.
You need to find the original cable or puchase one from HP.
I think they make serial cables where you can change the pin-outs but you would have to find one and figure out the correct pin-outs.
If this helps please vote for my solution.
Aug 12, 2009 | HP R5500 XR (326529-b31) UPS System
UPS Cables
some ups connect with
usb cable (universal serial bus)
ethernet
or serial data cable
Jul 12, 2009 | Computers & Internet
Do I have a Serial Port on my acer window vista home premium mfg date 12-18-2007
Most newer computer do not have serial ports but there is such a thing as a USB to Serial converter that might work to load what you need to load. USB to Serial converters don't always work but they are worth a try
Nov 09, 2008 | Computers & Internet
585avr isn't working w/vista OS,
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @ http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
Oct 31, 2008 | CyberPower Office Power 585AVR...
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
You can see my response below
The geek squad has my computer. they need the start up disks to reboot. the serial number cag5110022109does not do anything when put in the link you gave me.
Sep 02, 2008 | Computers & Internet
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
