Question about Philips Televison & Video
32hf5445/10 As a hotel we do not know how to get it working? Surely it will tune into a local tv station, not yet digital transmissions? i cannot get a menu to come up on the screen? As an ex TV engineer I do have a little knowledge but admit I am not up to date!!!! Can u please help? Andrew maint dept
likha
  • 790 Answers
SOURCE: Tuning an Akai Television
go to settings! then select auto search!
Posted on Oct 02, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
jerryg50
  • 1673 Answers
SOURCE: sony kv32ds60u engineers menu
If you did not save the damage that you did, or do any damage from over-adjustment, you can make a re-set to before the adjustments were made by simply unplugging the set from the AC mains for about 10 to 20 seconds. If the improper parameters were saved, or damage was done from over adjustment, then this procedure will not work for you.
Read on for more details:
There is no default actual default. Each set is individualy set up for its optimum performance. At the factory, during the manufacturing process they set the EPROM firmware parameters to a so-called reference value before they start the calibration. This is done during production on the burner that programs the EPROM.
If the paramters are too far off to have the set working, you will have to take the set for service at a factory service rep. The factory service shop will most likely have to change the complete circuit board that constains the uPC EPROM with a new one that has the reference factory set-up. They will then have to go through the complete set-up with calibration procedures using the factory recomended calibration standards instrumentation to match for best performance. To manualy do a full calibration on the test bench it can be about 2 hours of work.
Because the factory service setup was not meant for consumer use, it is possible to over adjust parameters to the point where you can lock the set out of operation, or actualy do damage by over-adjustment.
Jerry G.
Posted on Apr 19, 2008
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
My tv screen says no signal with the coaxial cable hooked up
Is your TV aerial plugged in. Do you know if it works. Are you tuning the digital stations (you should be. There are no analogue transmissions any longer)
Sep 09, 2014 | ViewSonic Televison & Video
When I auto scan channels it want find none. what do I do??
Sep 09, 2014 | Televison & Video
Hotel TV
check in preset under menu the channels 30 above maybe skip, set this channels to skip off. or just do the auto tuning.
Jun 11, 2009 | Zenith C27A24T 27" TV
My digital tuner does not work
have you tried entering the "tuning mode" and scan for possible channels?
if not , check for screen "menu" go to "tuning mode" and select auto scan
Jan 13, 2009 | RCA TruFlat 27F520T 27" TV
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Sony KV14T1U tuning
Press and hold for a few Seconds the 2nd Button from the left on the front of the TV. The auto tune menu will appear on the bottom right of the screen. Wait until it disappears and then check the channels by using the buttons on the remote.
May 20, 2008 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
