Question about Lexmark X5470 All-In-One InkJet Printer
Fax issue on X5495
I am using DSL- Do i need to use a Filter to use the line for Faxing
If your running DSL and even if it is a separate number, you still need a filter on it regardless. Home security systems, fax machines, any and all phone lines, answering machines, all these devices will need a filter on them.
Posted on Jun 27, 2008
  • Lexmark Master
  • 2,794 Answers
Yes you do unless it is a seperate phone number for your fax line.
Posted on Jun 26, 2008
Error #252
This is a poor fax line error. The line quality has noise or some issue causing the fax receive /or send to fail , often people use the same line for faxing and ADSL (telephone provided internet) and this will cause noise on the line. To fix this I have used a noise filter that came withe the DSL router from the Telco. sometimes ive even had to use two, one on each end of the phone cable before the line was clear enough to send and recieve faxes without a problem. If this is not your case, have the person sending the fax do one at a time or vice versa. Hope that helps you Gurvy
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Faxing with a digital phone line
I looked up fax problems at HP.com and my guess, based on what I read, is that the 6110 is able to detect the broadband data connection at the higher line frequencies, even though all you hear on the line is a normal dial tone. If you haven't done so already, you'll need to install a line filter on one of your phone jacks (this should have come in the kit with the rest of the hardware you were sent to set up the DSL line). This isn't an issue with the 6110, but a natural "consequence" of using DSL.
Here's the web page I used as the basic for this opinion:
Phone "Off the Hook" Status
On that page scroll down to the "Checking the phone line" section and read the material there. See if that info helps. Good luck.
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
DSL FILTER
I know that my DSL filter is plugged in to my telephone socket, it has about a 6 inch lead from the phone socket to the filter so it should be quite close to the socket.
Hope that helps.
Mike
Oct 16, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon fax problem
Unless that phone line is filtered in a back room somewhere, that could be the reason why it isn't working. The best way to find out is to put your fax machine onto on hook dial mode and listen for the tone. If you don't hear one, your fax line isn't filtered and needs a filter in order to use the line for faxing.
Jul 28, 2008 | Office Equipment & Supplies
Faxing errors on comcast digital voice
I am afraid to inform you that Comcast does not support faxing.
Please click on the web link given below to get the answer.
http://www.comcast.com/customers/faq/FaqDetails.ashx?ID=2189
Have a great day!
Feb 09, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Canon m830 faxing problems
Do you have a filter on the line? Also make sure the phone line from the wall is plugged into the jack in the back of the machine marked "line" and not "phone"
Dec 06, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X5470 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
