HP 2840 10.1004 SUPPLY ERROR - Office Equipment & Supplies
  • 2 more comments
  • Anonymous Sep 02, 2008
    I have replaced the imaging drum but it keeps coming up 'Reinstall'. I have taken it out and put it back in a number of times but it is still showing the same error message.
  • Anonymous Nov 25, 2008
    How do I replace the chop?
  • contact983 Nov 25, 2008
    How do I replace the chip?
  • Anonymous Dec 22, 2008
    I don't know which of the cartridges would've failed though...
This indicates one or more of your cartridges has failed.
probably just needs the chip replacing on the relevant one.
Posted on Jun 26, 2008
Bin the machine!!!! Go paperless, its ruddy lovely like
Posted on May 15, 2009
How do i fix my hp5550 error supply code 10.10.00
Here is the HP Laptop Technical Support Number 1-844-355-5111 (toll-free) to fix hp 5550 error code by expert technicians.
HP Laptop Support Number 1 844 355 5111 Laptop Repair
Apr 05, 2016 | HP Office Equipment & Supplies
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
Error 58.04on hp cp3525n Support
Low voltage power supply has a problem.
If after power cycling the printer snd the error still appears,
then the Low Voltage supply will have to be replaced.
Nov 02, 2011 | HP CP3525N Color LaserJet Printer
Hi, i have cp2025 printer and it giving an error 58.04 could you please help thanks
Solution or Workaround:
NOTE: Replace the low voltage power supply before replacing the fuser or fuser power supply.
A firmware upgrade is available on www.hp.com that will solve this issue.
If the error will not clear after the firmware upgrade, replace the low voltage power supply.
If the error continues, replace the fuser power supply.
If the error still continues, replace the fuser.
Cause:
Low voltage power supply malfunction.
I hope this information helps
May 12, 2011 | HP Laserjet Cp2025n Printer
I have a printer HP CP2025, it gives me the follwoing Error 58.04. What I can do ?
Cause:
May 10, 2011 | Office Equipment & Supplies
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
Hp laserjet m1522nf 10.0000 supply memory error
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
May 20, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Try another toner. Most likely the chip on this one is bad.
Apr 07, 2009 | HP LaserJet M1522n MultiFunction Printer
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
3,260 people viewed this question
jasbo
jasbo
