Question about Canon NP 6035 Copier
Printing on Canon NP 6035
We have got Canon 6035 copier and we would like to print documents from a Windows XP Pc to the aforementioned copier. Any network driver for that? assist
  • csoundo Jun 26, 2008
    I understand NP 6028/6035 are old models. Would printing solution of higher models help solve my problem? if such network printing solution exists
  • Canon Master
  • 2,794 Answers
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Posted on Jun 26, 2008
  • Tim Babcock
    Tim Babcock Jun 26, 2008
    If you are using an analog copier, it won't connect to a network. You need a digital copier to do that. I believe NP copiers are analog.
    By getting a digital copier you should be able to scan, fax, and printer over a network.
    What part of the country are you located at?
  • mukhwana david Jun 11, 2013
    uganda
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
Jul 24, 2012 | Canon NP 6035 Copier
Not printing
I dont think this copier is made to print. Or are you trying to say it doesnt make copies?
Aug 10, 2010 | Canon NP 6035 Copier
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
How to replace the cleaning web in Canon NP 6035 copier?
You must remove the fixing unit and just look how is assemblled and dissass. it or you can call the service
Jan 09, 2010 | Canon NP 6035 Copier
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
Dec 16, 2009 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Hi,i have a canon NP 6220 Photo Copier but i have faile to connect it to my PC in order to print documents. Please can you help? Kevin.
Sorry, the Canon NP 6220 is an Analog copier. All NP series copiers are Analog. You need a Digital copier in order to connect to a PC.
May 26, 2009 | Canon NP 6545 Copier
Faded black and white print out (Canon NP 6035/6028)
Are you getting a E0020 code? If not there is nothing wrong with the hopper. Has the OPC unit been replaced recently? Also, have you looked at the developing unit? Dose the developer Mag. roller have a even coat or brush on it? If not have you cleaned the S-Blade or doctor blade? Also, have you cleaned the optics?
Aug 13, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
106 people viewed this question
old marine
old marine
