Question about Hitachi (GD-S200) (GDS200) DVD Drive
Hitachi HTS541680J9SA00 DvD Drive not working
My dvd drive is still opening and closing but doesnt give any results if i put a cd or dvd in only a few revs, it also doesnt show up in my computer section either.
NU-MI FUNCTIONEAZA DVD-UL LA LAPTOP CE SA DAC?
Posted on Dec 01, 2008
Hmmm...
This identification number seem to identify a 2.5 inch Travelstar Hard Drive, not aDVD drive.
RFB
Posted on Sep 29, 2008
    Guru:
  • 859 Answers
Eject the Drive form your laptop, spray the inside with canned air, use a flashlight to see if the holes are occupied by something. Look at the pins for the drive at the back and see if they are all straight. If you have a bent pin tell me before you try to straighten it first, these break off really easy and there is a trick to straightening them. put your Floppy drive in the compartment if you have one and see if that device is recognized in Windows.
Let me know your results.
Regards,
Worldvet
Posted on Jun 27, 2008
I got me Dell LPTP 15 6 INSPERION 15 NOTEBOOK MODEL NUMBER 13552-4042BLK I got it used... So no manual..How do I play a DVD
Just hit the button on the CD drive and it will pop open.
Put in a DVD and close the drive.
Wait a few seconds and it will give you options.
Select "play with Windows Media Player" and you're done.
Mar 02, 2017 | Dell Computers & Internet
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
I have a Hitachi HTS541680J9SA00 dvd/cd drive as part of my laptop and it is no longer reading or recognizing dvds. I have uninstalled and reinstalled numerous times and still not working. It shows enabled...
Hello There and Welcome to Fixya,
Solution for this problem can be found through this link :
Optical Drive issues
The usual cause for this problem was due to conflicts happening inside the windows registry. By visiting the link above, you have the option to download the automatic fix by clicking on "Run Now", or you may choose to read the "Fix it myself" section for a clear, step by step procedure on how to do this manually.
I hope this helps and Thank you for using FixYa.
Feb 24, 2011 | Hitachi Computers & Internet
My Hitachi HTS542525K9SA00 has stopped working. In Device Manager it says its working okay. But, it won't recognize anything I put in it and I cannot burn anything.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 13, 2011 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
Where TO DOWN LOAD SOFTWARE FOR MY DRIVE MODEL GSL-T21N. DRIVE WORKS In MY other laptop and in this one, dell inspiron 1525, dvd cd drive only open and closes. doesnt appear in My Computer Drives. I want...
> it does not appear in "My Computer"
Does it appear in "Device Manager" with a "yellow-triangle" or "red-X" superimposed on its icon?
Since the tray opens/closes, it is getting electrical power.
Do you hear the drive spinning a disk, when you close the tray?
Sep 15, 2010 | Hitachi Computers & Internet
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
CD tray does not open when Button Pressed
does the tray open when you right click on the drive icon in "My Computer" and select "eject"?
Oct 25, 2006 | Sony DRU-810A DVD RW Dual Layer Burner
Hitachi (GD-S200) (GDS200) DVD Drive Logo
931 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
