Sony KP-61HS10 61" Rear Projection Television Logo
Posted on Dec 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color convergence shake's but does not aline. What convergence chip would that be! Thank you.
Anonymous
Level 3:
  • Sony Master 3,459 Answers
  • Posted on Dec 03, 2010
Anonymous
Sony Master
Level 3:
Answers
3459
Questions
5
Helped
849948
Points
5558
Every model has different chip sets. Check with www.TvRepairkits.com
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
53UWX10BA , changed the STK chips, inspected and tested resistors - still have the convergence problem of Green, Red, and Blue out of aliagnment. What are the next steps? Could I have damaged the STK...
Have you tried to alined TV with the Convergence Pattern on? OR
Do you Know how to get convergence Pattern?
Plus Whatever you do DO NOT CLEAR the DC ram board, it takes more then 6hrs to realined once that has been done.
When i turned the t.v last nite there is a blue outline to the picture. i tried to reset the alinement of the t.v but it won't work.
The convergence chip that was supposed to control the blue CRT has failed so the convergence board must be refurbished. Here is the repair kit
http://www.tvrepairkits.com/xcart/product.php?productid=21827&cat=2726&page=1
2helpful
Hi.all the color are not alined
Tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced on the tv convergence board to solved the tv picture convergence problems.
I have some distored blue color across the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
I have a Hitachi 60sbx78b rear projection tv when I moved the set about 60 feet to a new room.when i turned it back on I now need 3d glasses to watch it the colors are all out of aline and the green line...
Check your owner's manual and see if there are instructions for setting the convergence. This lines up the different color guns so that you don't need your 3D glasses. If setting the convergence doesn't work, you may need new IC chips. Good luck!
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
2helpful
Color
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Hitachi 50ux26b projection TV, the color lines separated...
It sounds like a convergence problem; either bad solder connections at one of the convergence Ic chips or a bad Ic. if this was helpful give me a vote----if one of the chips is now bad it will have to be replaced(usual thing is to replace all the convergence ic chips---most use two and a few 3.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
