Question about Garmin eTrex GPS Receiver
Etrex - can't find satellites anymore. Just stopped one day after downloading Points to my pc
Is there a global reset option for the etrex
  • 6 more comments
  • TomSM Jul 01, 2008
    Thanks for bearing with me and coming up trumps!!!
    Cheers TomSM
  • a1001smiles Jul 06, 2008
    Hi Benimur,
    im having a similar problem with a Garmin eTrex Vista unit. It displays a date of 12-Dec-24 and although displays that it has found satelites it will not lock on to give a position!
    i.e. i get up to 8 black bars at a good signal strength, but it still after more than an hour will not give a position.
    I have tried the second method you describe which didnt seem to make a difference. The unit gets to the disclaimer statement and then wont do anything unless i take my fingers of the buttons at which point it reverts back to normal mode.
    The first method im not sure about as i dont see any reference to a page up button in the manual?
    Any advice would be appreciated
  • Anonymous Jul 24, 2008
    Tried the recommended solution (page up/page/pwr on etc. still cannot read find satellites...... (yet it knows the date & time....). any other solutions?
  • govbug Jul 24, 2008
    Tried your solution to my etrex not finding satellites (Page up/page/pwr on) and it still can't find a satellite
  • jeff0352 Nov 11, 2008
    When I went into the service mode is there anything that ells me the unit is receiving sat signal
  • brainard941 Apr 15, 2009
    can't find satellites. used to hook up promptly, now can't locate.
  • jeszp Apr 23, 2009
    I have the same problem with the eTrex Vista. After resetting the unit, it will lock onto satellites (after 10 min) and then lose lock after 15 min. It use to work fine when I bought it, but performance has deteriorated over time. It also won't communicate over RS232 with MapSource. I won't buy another Garmin if this problem can't be fixed.
  • Anonymous May 04, 2009
    The reset seems to work fine on the basic etrex, but not on the vista. I cannot reach the service mode. Anybody any ideas?
    Brigadier General:
  • 6,966 Answers
To my knowledge, a reset on a Garmin eTrex would require:
Holding down the PAGE and PAGE UP buttons while simultaneously powering the unit. The Garmin eTrex will enter the service mode/display:
- Bravo Version
- Software Version
- Time
- Internal temperature of unit
- Battery voltage
- External voltage
- Button presses
- Other tech info
You can also perform an LCD display/screen check by pressing the PAGE button 2X.
A firendly word of advice: While entering the service mode is interesting and useful, be careful which buttons you press because it is also possible to rest the unit to factory settings within this mode. Pressing "up"+"enter"+"on/off" keys in service mode will reset the eTrex to factory defaults. All presets and data will be lost.
To exit just turn it off as normal, and then turn it back on as normal. Unless you deliberately reset the GPS, nothing should have changed.
Alternately, you can try: Hold down the find, click-stick, and page buttons. Press the power button, and when the title screen appears, release the buttons. This will clear all memory (you will lose all waypoints, etc. back them up first).
Find button: bottom button on the left
Click stick: the button on the face of the unit
Page: the top button on the right
Power: the bottom button on the right
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 26, 2008
  • Louie  Role
    Louie Role Jul 03, 2008
    Glad to be of assistance and appreciate the rating too.
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
My etrex legend won´t detect any satellites.
Make sure its not stuck in simulator mode in the setup menu. then update your firmware on the device. you can get it from www.garmin.com
if that doesnt work then there is something internally wrong with it and will need to be sent in for repairs.
Aug 14, 2009 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Venture doesn't aquire satellites
I have an eTrex and you can reset the defaults which may help. I don't see any 'reset' operation in the manual other than Restore Defaults.
After switching on and letting the unit go through its initalisation press the button on the front (next to the etrex name) until you get to the main menu. Select Setup and press. Select System and press. Move the button to the left and press. Press the button again to restore defaults.
HTH
Peter
Mar 05, 2009 | Garmin eTrex Venture GPS Receiver
Etrex legend has stopped picking up satalites.
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Mar 04, 2009 | Garmin eTrex Legend Cx GPS Receiver
Wait...Tracking Satellites
Turning off WAAS and then "Super Master Reset" (then reacquiring signal normally) did the trick for me. Note that it will wipe out ALL saved waypoints, so write 'em down before trying. This link describes it:
http://www.fixya.com/support/t260605-garmin_etrex_vista_date_problem
Jan 12, 2009 | Garmin eTrex Vista GPS Receiver
Etrex wont find satellite - how do you update software
If you are talking about a firmware update then that's involved. To find SATs choose the menu option on SAT refersh.
Dec 23, 2008 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Etrex satellite problem
Hi again,
Appreciate the update.
Have you tried both methods?
Jun 30, 2008 | Garmin eTrex GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex GPS Receiver Logo
2,387 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
