Check the Vs and VA voltages to plasma panel. If these voltages, that comes from the main power board is abnormal, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
The booster motor? Do you mean the inducer motor that helps push the exhaust? If the inducer motor won't shut off when the thermostat is satisfied and everything else does shut off, it sounds like the contacts on the relay that powers the inducer are at fault
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected. Welcome To the Best HVAC
What is the fault with your Plasma TV? You haven't provided any details of problem you are facing to your Plasma TV. Anyway, get in to this site named 'electro-help'. Faults with plasma TVs are described there. In most cases, all plasma tV will have similar problems, and repair work to them will also be the same. Just check this link, and select the site named above for details.
No,don't buy plasma tvs any tvs make or tvs brand.Don't buy any kind of tvs using plasma gas as for plasma screen panel as a power sourced if u play major hours of gaming on the plasma tvs,u will still have thermal expansion problems but less.Plasma tvs still have major problems,with screen BURN IN problems though.
If you can turn it back on with the s momentary key or power button:
When it shuts off, do you need to push the power button once or twice to get it back on? Also, does anything else about the picture or sound change as it warms up?
If once, then the controller is shutting the TV down either as a result of a (thermally induced) fault in the controller or it sensing some other problem. Monitoring the voltage on the relay coil (assuming these is one) could help determine what is happening. The controller thinks it is in charge.
If twice, then the power supply is shutting down as the controller still thinks it is on and you are resetting it. A couple of possibilities here would be low voltage or high voltage regulation error (excessive high voltage is sensed and causes shutdown to prevent dangerous X-ray emission). A partially dried up main filter capacitor could also cause a shutdown but there might be other symptoms like hum bars in the picture just before this happened. Clipping a good capacitor across the suspect (with power off!) would confirm or eliminate this possibility.
If it uses a pull-knob (or other hard on/off switch), then this may be like pulling the plug and would reset any abnormal condition.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
I think you have a fault on the line output stage either dry solder joints or a fault with components on the line output stage or a faulty line output transformer. If you can check this for yourself otherwise find a competant technician. Hope this helps.
