Question about Goodman Heating & Cooling
I have a Goodman CK36-1B aisconditioner unit. The condenser unit has stopped. When i turn it on you can here it runnibg but the fan doesn't move. I replaced the capasitor last year. You can also fel heat build up in the unit. How do i check it out?
SOURCE: Goodman Condenser - Heat - Buzzing Noise every 60 seconds
You stated capasitor was checked . if cap. is ok sometimes start terminal wire will burn into at compressor or you may have a loose connection causing a voltage drop (more than 10%).If both check ok try a hard start kit. Who knows it might start. good luck
Posted on Jan 20, 2008
koolbreezes
  • 540 Answers
SOURCE: Goodman CKL60-1 Condenser Fan Runs OK, then stops
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Posted on Aug 25, 2008
  • 182 Answers
SOURCE: Copleland scroll compressor failure
Make sure ALL moisture and noncondensables are evacuated while the system is down.I would have the line flushed to remove all remnants of burnout.Actually with the age of the unit and amount that needs repaired I would change the unit out to a 410a system and start over.
Posted on Nov 02, 2008
pierre1811
  • 144 Answers
SOURCE: heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Posted on Jan 18, 2009
farfield
  • 462 Answers
SOURCE: Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to rep
A new unit will be 13+ seer unless you can find someone that has replaced a compressor or has one left over from pre 2006 stock. Our wise Government with all its resources decided that we aren't smart enough to turn off the lights to save energy, so they chose to end the med and low price lines. And the same bunch of smart ones decided that now R22 because of its chlorien content being bad for the air (5% of what R12 was) so we have R410A and others that no one knows how much cancer or daMAGE THEY WILL DO OVER TIME. So now if you replace your AC unit out side with a new one be sure its compatable with the refrigerant inside and beware soem manufacturers wont stand up to full warranty if you dont buy an indoor coil and rerplace it too.
We get what we deserve in Washington DC and if our guy didnt support this stuf too many other folks guys did. We just dont talk about it enough. AND WE SHOULD. But then again you like me are probably RITCH. So we have to give up our wealth to the government so they can redistribute it and buy more votes. And we can stay working too much to talk about it.
Just burns my back side like a 4 foot flame.
Read tween the politics and you'll get my recomendation.
Buy your self a compressor and get someone qualified to install it or see if the old goodman one will interchange easily.
Posted on May 12, 2009
Goodmans troubleshooting
Hi;
You don't mention the fan. It is at the top of the condensing unit and should be running whenever the compressor is running. The water is doing the same ob the fan does, removing the heat from the refrigerant . What led you to put water on it?
Jul 30, 2014 | Goodman Manufacturing Goodman GSX130481...
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
Unit will not run. Changed the capicator and it still does not work.
what doesn't work? the condenser the fan the compressor ? need more details
Aug 12, 2011 | Goodman CKL42AR42 Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
I just moved into a brand new home that has cental air (Goodman air conditoner) how do I turn on?
turn the thermostat to cool and turn the temperature down if it still doesn"t run check for double pole breakers that are off
Jun 30, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman A/C model ch42-1 cooling fan not working
These motors start with the capacitor,that could be the problem in most of the cases ,but sometimes even if the capacitor is new they don't start or after a while they stop by overload.First try replacing the capacitor(no more than $10) and keep an eye on it beacause if this fan at the condensing unit doesn't work it could damage the compresor.
Apr 23, 2009 | Goodman CKL42AR42 Air Conditioner
Heating & Cooling Logo
862 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
