Question about Gateway GT5220 PC Desktop
Gt5242e will not power on no lights fan will not come on and will not beep
Had a similar proble,. Took it to my IT guy. Was a blown CPU and motherboard.
harrythek.
good luck
Posted on Jun 26, 2008
How to reinstall missing wmf graphics filter
SYMPTOMS
When you start any of the programs listed at the beginning of this article, you may receive one of the following error messages:
One or more components are missing or broken. WMF graphics filter is missing.
Wmf graphics filter is missing.
CAUSE
This behavior can occur if the Windows Metafile (WMF) graphics import filter is damaged or missing.
RESOLUTION
To resolve this issue, rename the Wmfimp32.flt file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named field, type wmfimp32.flt.
- In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box.
- Click Find Now.
- Right-click the Wmfimp32.flt file, and then click Rename.
- Type wmfimp32.old.
- Press ENTER.
- Close the Find: Files Named Wmfimp32.old dialog box.
- Reinstall the program.
I hope that this helps!
Apr 24, 2012 | Gateway GT5242E PC Desktop
Gt5242e stoped working
Can you give us a little more to go on?
Jun 16, 2011 | Gateway GT5242E PC Desktop
My fan starts but the light doesnt turn on and the monitor doesnt display anything
A loose contact on the SATA bus ports (a red colour cable connecting Hard disk and motheboard) is the most commom reason. It becomes hard and shrinks after a period of time causing poor data flow.... Remove Power from PC gently push the SATA cable, Plug it back and try to start PC
OR consult hardware engineer
Sep 28, 2010 | Gateway GT5242E PC Desktop
Age
Hello
unfortunately you do not give sufficient information on the problem. Please be more specific. Try to explain more exact details on the problem.
Kind regards
Andrea
Aug 16, 2010 | Gateway GT5242E PC Desktop
Blue power light does not come on when i turn the comp on
there is either a motherboard/cpu issue (worst case), or a power supply issue (best case, cheap and easy fix)...
without being there looking at it i can't really tell you more. if you happen to have a spare ATX power supply, open the machine and plug it in to the system instead of the old one to see what happens.
if you don't have a spare, you obviously have another working computer you're posting from so maybe borrow it's power supply and see what happens.
Jul 30, 2009 | Gateway GT5242E PC Desktop
Computer will not boot up when turned on. light on tower not lit just runs no screen images
first step to determine the damage and is again re-work order, open the cover of the CPU and remove the following parts, the first memory is the second video card and third is the IDE cable connectors, clean the small feet and the second memory is please clean feet video card if it is you video card, good luck
Jul 29, 2009 | Gateway GT5242E PC Desktop
No sound after reinstallation of os for my gateway gt5242e pc xp
Looks like you need drivers for your audio hardware, unfortunately, Gateway's support site (now affiliated with Acer) does not provide the drivers directly, instead they provide a driver update utility that will hopefully find the right drivers to get your sound working again.http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn&param=gtwupd.exeHope it helps.
Jun 11, 2009 | Gateway GT5242E PC Desktop
Boots to desktop stays on for about a minute or two then shutsdow
Sounds like the processor is overheating. Check to make sure that the processor fan is running and that the heat snyc is secure.
Feb 09, 2009 | Gateway GT5242E PC Desktop
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Gateway GT5220 PC Desktop Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
