Question about Muratec F360 Plain Paper Laser Fax
Muratec F-520 Cutting off 1/2, sometimes 1/4 of a page when copying or scanning. Will scan the pages and when you see the copies they are not complete. Any ideas?
  • mosgoe1 Jun 26, 2008
    This machine does not have the glass option.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this happening when documents are being scanned through the document feeder?
    Does this happen when they are scanned directly from the glass?
  • 2,794 Answers
It could have something to do with the automatic document feeder. There could be something in there that is blocking the paper from feeding in there correctly. It could be the feed tires or the belt as well in the document feeder.
It should be looked at by a technician in your area in case there are some parts that need to be replaced.
Posted on Jun 26, 2008
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Want to scan 10 pages in a document
you could scan the pages and copy paste them into a word or Adobe PDF document
Apr 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Top Feeder scanner leaves a line along the copy
This Is good for all "all in one machines"
There is a dot on the 1inch glass, when making a copy or faxing or scanning it makes it form that part of the glass. It shows as a line because the paper is moving as it is being scanned. clean the glass w/ alcohool. Sometimes it is hard to see because the background is black and the dot may be a pen or pencil, but it's there.
try to take the copy and lign it up w the glass and look where the line is you might see it htere.
Oct 10, 2007 | HP LaserJet 3055 All-In-One Printer
Muratec F360 Plain Paper Laser Fax Logo
213 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
