Canon520 ink storage full. will not print. How do I clean?
    Genius:
  • 2,785 Answers
Plz check the website below
http://www.fixyourownprinter.com/forums/inkjet/50418#1
after that if you the problem is not solved then you have to the printer and locate the pad below cartridge resting place,remove the pad and wash and dry it.
Posted on Jun 26, 2008
My Canon MP210 printer has full in waste baskets. How do I clean them?
Turn the printer on.
Lift the lid that covers the print-head.
Notice where the print-heads are located, as soon as you can see the print-head.
That position is the "storage" position, and the "waste ink bin" is the sponge-like material
that is below the print-head.
Wait for the print-head to slide to a different position (from where you change the ink-cartridges).
Then, unplug the printer from the AC power -- do NOT press the ON/OFF button.
Now, use some paper towels to absorb some of the "waste" ink.
The amount of "fullness" is ELECTRONICALLY measured, i.e., it is calculated, based on how many pages you have printed, how often you have printed, and so on. It's not MECHANICALLY measured, unlike the gasoline gauge in your automobile.
So, now you'll need to do a Google-search for a sequence of key-presses that will "reset" those ELECTRONIC counters for your specific model of CANON printer.
May 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My lexmark 3550 printer wont print
Hi
If you have storage your printer for nearly a year then myself I think the heads have gone dry and blacked you will need to clean the heads, if the heads are on the inks then no problem just get new ink but if it been standing that long and the heads are on the printer itself and not on the ink cartridge then you will have to find the heads some will clip out but some will have to be screwed out and then you can clean them by dabbing a little worm water on a cloth on the heads to try get them clean.
It not good to leave them standing, if you go to store them for a long time then you go to take out the inks and clean the heads before storage.
All The Best: Pineworks
Jan 31, 2010 | Lexmark X3550 All-In-One Printer
Will not print in color, but black cartridge is printing fine. I cannot find where to try and clean printyer head, etc. Cartridge shows to be full.
You find the printhead cleaning facility in the services tab of your print menu box. However I assure you, more often than not this is not enough to get the desired results. If you want best results folow the procedure below, tis simple and effective only a bit technical.
Ink may be new or full, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles however, the procedure may be repeated over to get results.
Dec 14, 2009 | Dell A960 All-In-One InkJet Printer
Ink well transformer full
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I have cleaned the waste ink resavoir but I keep getting the message that it is almost full. How can I reset it?
HI ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... cheers :)
Aug 07, 2009 | Canon PIXMA iP1600 Printer
PRINTING
tray a clean nozzle and alignment from printer manager, first..that might need to be done a few times
Apr 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
My HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
Mar 28, 2008 | HP cp1700 Color Inkjet Printer
Ink tank absorber full
Hi ....
Do vote if this helps ... Cheers :)
Jan 26, 2008 | Canon I990 InkJet Photo Printer
54 people viewed this question
jasbo
jasbo
