Samsung WF 338 washer
We have just purchased the Samsung WF 338 washer and the pedestal...... The machine vibrates violently for just a few seconds as it it going into the spin cycle.. once it is in a full spin it's fine.... is this normal? Is the washer sitting on the pedestal too top heavy???? and maybe that is why it is vibrating...... the washer is leveled!!!
  • endingo Jun 26, 2008
    Thanks for trying, the shipping bolts have been removed. Do you have any more suggestions? Do you know if the little rubber squares are suppose to be between the pedestal and the washer... I read on one of the postings... but it was another kind of washing machine and they said that only the dryers have these pads between the dryer and the pedestal.... don't know if this holds true for Samsung.....
    Thanks again for getting back to me and your knowledge.
    Barbara
    Problem Solver:
  • 12 Answers
Hello.
These are usually shipped with a number of "shipping bolts" to lock the drum in position during transit. If they are not removed when it is installed, then the washer will behave exactly as you describe. Check the manual or look for a sticker on the back or the washer showing which bolts to remove,
-ellie
Posted on Jun 26, 2008
  • Elizabeth Greene Jun 27, 2008
    On Mine, a maytag, the instructions indicated to remove the little rubber bits, and there was an additional set of shipping rods at the bottom of the machine.
    Has it ever worked right?
    -ellie
My washer is making vibrating, squealing and scraping noises. Recently we purchased a pedestal drawer by Frigidaire and installed it
Hi Stephanie,
The higher you raise the dryer, the more pronounced the vibration will be. This can be a result of worn bearings or spindle the allows the drum to spin around its center easily. This is not really a DIY project unless you've got tools and a fair amount of mechanical ability.
The scraping sounds may be from these same bearings and spindle parts - but can also be the result of worn out drum glide pads on the front of the dyer that supports the spinning drum. You can purchase these as an entire set (model specific part) and replace these fairly easily with a few simply tools and modest amount of mechanical ability. You can see the process in this video:
Dryer Repair Replacing the Dryer Drum Glide Whirlpool Part 37001298
You can reduce the amount of shake by slipping vibration reducing pads such as "Shakeaway" from Lowe's (and others). If one set under the dryer doesn't provide satisfactory results, adding a second set under the pedestal just might.
Dec 29, 2014 | Frigidaire Washing Machines
HE Kenmore washer vibrates quite strongly on high spin, which is the Normal default for the machine. I have had it adjusted for levelling, then had to have a new machine delivered when the vibration...
most of the kenmore front loaders is that way,, if it is on a pedestal or on the second floor it makes them worse,, lg samgung electrolux all shake to a extent but kenmore is the worst
Jan 23, 2011 | Kenmore Washing Machines
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Vibration
Does it have runner pads on the leveling feet on the washer resting on the pedestal?
If so, and it still moves all over, you will have to fasten the washer to the pedestal with bolts and nuts. I had a GE that did the same thing. I finally laid them on their side, drilled out the holes to fit bolts and washers I bought from Home Depot. They really don't make that clear, do they?
Sirwriter
May 06, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
Feb 16, 2009 | LG WM-2277HW Front Load Washer
Too much vibration
first make sure the floor is leveled and sturdy enough to handle the machine.
Nov 19, 2008 | LG WM-2277HW Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Jan 28, 2008 | Washing Machines
Washing Machines Logo
421 people viewed this question
Top Washing Machines Experts
