Question about SanDisk Sansa e200 MP3 Player
Sansa e200 It froze while refreshing database.It doesn't turn on or off unless the battery is out.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
REFRESH DATABASE
Remove the 4 back panel screws and take the battery out. Wait about 30 minutes than reinstall the battery. This should force it to reboot and load the program from ROM.
Jun 22, 2009 | SanDisk Sansa e200 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database
Sansa e200 provides a RESET function for unresponsive units. Press and hold the MENU button for 15 seconds, and this should work to regain normal funtionality. Please note: settings and adjustments from the last operation WILL BE LOST. The files however should remain.
Sep 19, 2007 | SanDisk Sansa e200 MP3 Player
My e200 mp3 sansa player can get refresh database
Hey Do the recovery Turn ur mp3 off lock it and hold rec and on it wiil have u plug in the usb cord and leave it there for 5 min And unlock then it will turn back on its self
Aug 19, 2007 | SanDisk Sansa e200 MP3 Player
PLEASE HELP
U have to restore the factory settings and check again..... If it does not work then Recover the player by using sansa recovery tool. The link for this tool is http://mp3support.sandisk.com/tools/DeviceRecoverySetup.exe The instructions u can find in the following link http://sandisk.com/assets/File/pdf/retail/connect-recovery-instructions.pdf
Jul 02, 2007 | SanDisk Sansa e200 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
20 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
