Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis Francis..why do you turn off the power???
I have had this problem with my exploding X1 machine!  After no problems for about 18 months, the unit now trips the power in the house every time it is switched on..the first couple of times it happened, smoke was rising from it.  Bad enough as that is, I bought the same machine for my brother+wife for their wedding. They only got just over a year out of it before it started giving precisely the same problems.  I was hoping to find some answers on the internet, but lots of people reporthaving  this same problem, not many report a fix. This is surely a design fault of the product, but the only way to fix it is an extremely expensive trip to the repair shop. For me, doubly so! Please, any assistance. If I could source the replacement parts relatively cheaply, I'd fix the machines myself, but I can't find any links to the company website, or anyone who might confirm for me what the issue may be (as both machines display the same symptoms, I think it fair to assume it's the same problem)
  • Anonymous Aug 14, 2008
    I have a similar problem. My machine is about 3 years old. Typically it trips the GFI when I am trying to make a second cup too soon after the first. I know the instruction manual said not to make cups in quick succession. So I was thinking the problem was caused by the boiler being too hot. If as has been said it is due to the element touching water and this is due to scale build up, would descaling/cleaning not help...though I am not sure why that would stop the element touching water. I am still confused but will try cleaning. I also recall a guy in Williams Sonoma I think once told me the boiler burns out in close to 2 yrs
  • 3 Answers
Generally in the case that a FF machine is tripping the GFI it is because the heating element within the boiler is coming in direct contact with the water. By this I mean that the coating on the element has deteriorated or the element itself split apart. This is usually do to a lack of cleaning or descaling. It is the machines defense to trip the breaker to avoid any further issues. As far as I know there is no way to repair this problem except sending it in to a repair center.
Hope this helps
Posted on Jul 14, 2008
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Francis francis espresso x1 not turning on
The most obvious thing is the fuse in the plug. There are no fuses inside the francis francis (at least in the model I have).
Aug 30, 2014 | FrancisFrancis! Francis Francis 207003 X7...
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Apr 30, 2010 | LG WM2016C
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
313 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
