Question about Kyocera Office Equipment & Supplies
KM-3050 KX error code C5300. Is there any quick fix or do I call a technician?
    New Friend:
Km5050error code displaying c5300how can i remove this code.
Posted on Mar 23, 2013
  • 45 Answers
Error C-5300 can be caused by a faulty drum unit but sometimes can be the result of poor contact in one of the door switches. Check both the front door and left door switches, making sure sure that both actuate fully when the door is closed. The actuator flag on these switches can become bent and cause poor contact. Carefully bend this flag out to ensure proper actuation.
Posted on May 08, 2014
It from a broken cleaning lamp wire, replace the drum unit and it should take care of the error.
Posted on Jul 19, 2012
4 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: SYSTEM ERROR
The Kyocera MK 3050 shows system error. We have turned it off and back on this does not help.
Posted on Nov 12, 2008
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
HOW CAN I CLEAR ERROR CODE CFB 30 ON KM 3050
Abort Code recommended you have a tech come and re-flash the copier firmware. Firmware is the copiers Operating system not a driver. Firmware is only available thru secure server available to dealerships and KMBS
Jan 30, 2016 | Kyocera Mita KM-3050 4050 Toner Black...
Kyocera km 2540 error code C6150
Refers to an Abnormally low fuser thermistor edge temperature. Your machine could not warmup. Fixing error codes (C6xxx series) must be reset by a technician after clearing the cause of trouble. Reseting a fixing code without proper repair may result in fire or damage.
Sep 04, 2014 | Office Equipment & Supplies
Error cfb30
Try upgrading the latest firmware
Aug 24, 2014 | Kyocera Copystar Fax System M Km-5050...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Have error: C6000 on Kyocera KM-3050
Aug 02, 2008 | Office Equipment & Supplies
4,987 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
