Question about Panasonic NV-GS4B Mini DV Digital Camcorder
Mini DV connected to Dell PC by 1394 cable
Pinnacle Studio SE cannot initialise capture device.
Panasonic VFF0154 USB Driver installed but " Removable Disc" is not added in My Computer.
Also USB Mass Storage Device is not displayed in Universal Serial Bus Controllers in Device Manager in Hardware.
Can you help?
Mr J Thuburn.
  • 2 more comments
  • pratchett Jun 26, 2008
    Dageezer.
    As a newcomer to computers I need to have detailed step by step instructions to follow your advice.
    Can you still help please?
  • pratchett Jun 27, 2008
    I already have current updates.
    New XP patch not appropriate.
    Any other solutions?
  • pratchett Jun 28, 2008
    BearWeb
    I have used this version of Pinnacle on many occasions previously without problems using the same camcorder.
    Now when I try to install the Panasonic USB Driver the Hardware Update Wizard says " The hardware was not installed because the Wizard cannot find the necessary software. Please advise.
    I have already tried this with no success.
    I think Dageezer may have been going in the right direction but I have not sufficient computer skill to follow his advice.
    Pinnacle,Windows Movie Maker, and AVS Media all cannot initialize the DV capture device.
    My PC will not accept the Panasonic USB Driver softwear.
    Please advise further.
    Sergeant:
  • 275 Answers
Turn on your pc and go to bios by pressing del or F2 or F10 depending on the motherboard you use. try to find usb controller or advanced-> usb controller menu in bios and check whether usb is enable or disable.enable it if disable and press F10 to save your setting.
Posted on Jun 28, 2008
    President:
  • 2,712 Answers
It could be that your software disc is corrupt and you will need to download the software from the website.
Try this: First uninstall the previous software installed. Restart the computer. Switch on your cam, and plug in via USB. Wait a while and see if it is detected at all, without the software. If it isn't, you may want to check this article:
http://www.thedave.ca/wordpress/index.php/2008/01/05/windows-vista-usb-device-detection-problems/
If it is detected, then the issue is with the software, and as said before, you will need to download it again. Try a clean install as outlined here:
http://www.fixya.com/support/r643558-clean_boot_in_vista
Hope that helps. If it doesnt, please post back, and I will try to assist further as best I can. Should you find the solution helpful, kindly take a moment to "Accept" my solution.
Thanks.
    Guru:
  • 1,894 Answers
I would suggest you to remove the drivers and then reinstall them
this would surely help you
    Genius:
  • 1,011 Answers
Sir,
This problem occured due to not installed the USB driver software. Install the Supplied USB driver software and restart the computer. it will works.
Thanks
Good luck
"Don't forget to rate the solution"
Posted on Jun 27, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Jun 28, 2008
    Dear Sir/Madam,
    Ok first you cant transfer videos recorded onto Mini DV to a computer
    via USB. To transfer them you will need to make sure that your computer
    has a firewire port ( IEEE 1394) this was an option on that model of
    Dells. If you dont have one you will need to buy a USB firewire capture
    device. I have included a link to one below. Next if you did have a
    firewire port, you will need to buy a 6 pin to 4 pin firewire cable and
    then plug the the 6 pin end into the machine and the 4 pin end into the
    camcorder. And finally you will need to use Movie Maker to capture the
    video.
    CLick this link for sources
    http://www.geeks.com/details.asp?invtid=...
    - USB capture device with Firewire input only needed if your computer
    doesn't already have a firewire (IEEE 1394) port of you buy this all
    the cables you need are included.
    - 6pin to 4 pin firewire cable only needed if you dont buy the item above, and you have a built in firewire ( IEEE 1394 ) port.
    Thanks
    Good Luck
    "Don't forget to rate the Solution"
    President:
  • 357 Answers
Hi there
I would recommend that you download and install one of the following programs. The problem with your current program (Pinnacle Studio SE) is that it does not support .DV file format
  • Pinnacle Studio Plus 9
  • Pinnacle Studio Plus 11
Bellow i will show you the advantages of Pinnacle Studio Plus 9 or 11
Pinnacle Studio Plus 9- Pinnacle has always amazed us with its Studio software for entry-level DV editing. Unlike many other programs at this level, Studio has been designed with the actual job of editing in mind, rather than simply being loaded with tacky special effects. The interface is visual and intuitive, and the package on the whole has always been packed with genuinely useful (and often quite ingenious) features. In recent years, however, we've been equally amazed at the program's flakiness and Pinnacle's inability to keep Studio's head above water.
Pinnacle Studio Plus 11- The newest edition of the best-selling Pinnacle Studio video editing software, Pinnacle Studio Plus Version 11, is all about innovation. This full-featured yet accessible application lets true video enthusiasts harness the power of the latest technologies without compromising ease of use. Pinnacle Studio Plus has an extensive range of capabilities which include compatibility with the new Windows Vista operating system, HD DVD and AVCHD format editing and disc burning, Hi-Fi audio music generation, and automatic Web publishing. With improved performance and speed, and a sleek new user interface, Pinnacle Studio Plus offers customers a video editing experience like never before.
Both of these programs support .DV Editing which is what you need.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Brigadier General:
  • 3,614 Answers
USB Connection Kit
(NV-GS4/GS5 only)
Using the supplied USB Connection Kit, you can import still pictures into your personal computer.
1 Install the supplied USB driver.
2 Set the Movie Camera to Card Playback Mode.
3 Set the Movie Camera to Still Playback Mode.
4 Connect the supplied USB Cable 1 to [USB] Socket 2.
  • It enters PC connection mode.
  • The USB Connection Kit can be used with Windows98 Second Edition/Me/2000/XP.
  • Use AC Adaptor as power source for the Movie Camera. (The Card or its contents may be destroyed if battery power is lost while transmitting data.)
  • Mode cannot be changed in PC connection mode by sliding [OFF/ON/MODE] Selector Switch.
Posted on Jun 26, 2008
  • micromaster
    micromaster Jun 26, 2008
    Personal Computer Connection Kit
    Using the optional Personal Computer Connection Kit, you can import still
    ≥Use the Digital Still Picture Terminal [DIGITAL STILL PICTURE] 1 when
    using the Personal Computer Connection Kit.
    ≥When recording, be careful not to cut off the Time Code from the start of the
    tape.
    ≥MPEG4 data or Voice data cannnot be used.
  • Panasonic Master
  • 2,794 Answers
You might have to reload Pinnacle studio if the software isn't recognizing it. Check with Pinncalesys.com to see if there is an update to your software as well before reinstalling it.
I've never heard of a DV camcorder being recognized as a removable disc. I know that DVD camcorders can be. Usually on a DV camcorder it is plugged into the computer, the power gets turned on and then it tries to connect to a program to capture the video from the camcorder.
A lot times DV Camcorders are plug and play requiring very little software. Once it is plugged in Pinnacle Studio prompts you to use the camera with the software.
I don't know too if this hase something to do with the software being an SE or not. I use a complete Pinnacle Studio system. You might want to check at pinnaclesys.com on that.
  • Tim Babcock
    Tim Babcock Jun 26, 2008
    If your using a 1394 cable it should pull up as a removable device in that area. It's seperate from the USB. I forgot that camera had a memory card in it and should detect as a removable device only if a SD card is installed in the camera.
  • Tim Babcock
    Tim Babcock Jun 27, 2008
    Theres a version 12 of Studio out now.
    Brigadier General:
  • 6,966 Answers
May I offer an alternative, it is possible that the issue has something to do with the USB in general. If you are using Vista, Microsoft has acknowledged this issue and has posted a patch/upgrade, Update for Windows Vista (KB940199) which can be found here. A similar patch is likewise available for XP here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 2,785 Answers
Plz open the device manager and unistall the pinnacle's driver then install the pinnalce's driver from the cd.
Please check in bios that your usb is enabled
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Jun 26, 2008
    plz open the device manager and unistall the pinnacle's driver then install the pinnalce's driver from the cd.
  • 796 Answers
Go to my computer -> properties
hardware -> device manager and scan for new hardware devices
  • isaac johny
    isaac johny Jun 26, 2008
    may be the usb card must have popped out of the mother board or some problem with the usb controllers
  • 3,940 Answers
Open DISK MANAGEMENT,see if there is a Drive letter conflict (USUALLY with Mapped drive)
INEED TO DOWNLOAD SOFTWARE TO CONNECT CAMCORDER TO MY PC TO CONVERT VEDIO TAPE RECORDED
To transfer video from this camcorder to a PC, you need a 1394 cable (also called a "Firewire" cable, and your PC must have a 1394/Firewire connector as well. You can use Movie Maker (which comes with Windows) as the capture software, or you can download Scenalyzer (shareware), Studio (from Pinnacle), or Vegas Movie Studio to do the capture.
Jan 25, 2011 | JVC GR-D870 Mini DV Camcorder
I need a MovieBox DV (1394)driver compatible with
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
Jun 25, 2010 | Pinnacle Studio MovieBox DV 9 (210100349)...
How do i hook my pinnacle to my ps3
To capture in Studio you need to know what type of device you will be capturing with.
There are 3 types
  • USB devices (like the 710&510 USB, and the Dazzle DVC 150 etc)
  • PCI cards (like the Movie Board, Movie Board Plus, 700&500 PCI)
  • 1394 cards
All these devices are setup in the same place in Studio but you will need to know what you have so you can make the right selections in the Capture source settings window.
To get to the settings window, hit the capture tab at the top of the screen from anywhere in Studio.
Note: When you go to the capture tab, if you have not changed the settings you may get a message saying it does not detect a DV camcorder.
When you hit the Settings button it will bring up this screen. Hit the capture Source tab. This is the capture source screen. This screen allows you to change what device Studio will use to capture. Notice the default is DV camcorder.
You can read the next step to hook your pinnacle up to youe PC reading the link below:
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=219835&Hilite=hook+piinacle
Hope it helps.
Mar 21, 2010 | Pinnacle Studio Version 11 for PC...
I need power adapter volt/amp
Looks like maybe 3.3 volts, 1.5 amps not sure of the polarity.
The Pinnacle Studio MovieBox DV Includes
  • MovieBox DV external analog to DV converter
  • Full version of Pinnacle Studio 9
  • Hollywood FX transitions
  • TitleDeko for titling
  • 4pin/6pin IEEE-1394 FireWire cable
    6pin/6pin IEEE-1394 FireWire cable
  • Power Cord
  • Power supply: 110V 60HZ 3.3V/1.5A
  • Studio Software 9 manual
  • MovieBox DV hardware manual
Dec 12, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Required USB Driver for mini dv Panasonic NV gs 15
The Panasonic NV gs 15 can only be used as a webcam with the USB cable.
You need a 1394 firewire / DV cable to transfer the video to your pc.
May 06, 2009 | Panasonic NV-GS15 Mini DV Digital...
Pinnacle Systems Studio V8.8 QS
Go into menu and look for AV/DV out, and turn on. this should be under menu under camera or video settings. I assume your output from your camera has not been established. I have to establish mine with my camcorder. hope this helps.
May 30, 2008 | Pinnacle Studio AV/DV version 8...
USB Driver
try this software im tryin it myself now!!
http://thepiratebay.org/tor/4058886/PANASONIC__DV_STUDIO_Version_3.12E-SE__USB_Driver
Dec 01, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic NV-GS4B Mini DV Digital Camcorder Logo
424 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
