Question about Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver
XM Radio Hello, I have XM Radio in my car. Recently I had my windshield replaced and the motor fixed on my sunroof. Now my XM Radio doesn't work, if it gets a signal its not a real good one and only for a few seconds than it says it has no signal. I am not sure what to do?
  • 62 Answers
I would check to see if there has been any damage to the antenna during the installations. You may just need to replace the antenna. Another thing to look at is whether or not the signal is being blocked by any of the new equipment installed. The antenna should have a clear line of sight to the sky. In this case you may need to relocate your antenna. If it continues to be an issue, it could be worthwhile to trouble shoot and see if maybe the dock or radio is causing the issue. If you have other equipment to test out, you can narrow down the issue and find a replacement at tss-radio.com
Posted on Jul 10, 2012
    Habit-Forming:
  • 17 Answers
Did you put in glass with conductive coated glass installed? It will shield your radio if your receiving or transmitting antenna is inside.
Posted on Jun 16, 2009
My XM just recently started to cut out in certain locations that had no problem before. It seems to be getting a good signal the screen display does not cut out. I lose volume and get static just in certain spots. Anyone know where I should start looking for a fix.
Posted on Dec 02, 2008
  • TSS Radio
    TSS Radio Jul 10, 2012
    You need to directly connect it for audio. You are not losing signal you are having interference with the FM frequency. An auxiliary cable or cassette adapter is a quick and easy solution. There are also aux input adapters, FM direct adapters, and FM transmitters that will help insure you don't lose sound quality. tss-radio.com can help you with all of these parts, and more.
Why does my XM radio lose its signal when the car's power is off?e car. When i refresh the signal it comes back on, but when I turn off the car, the signal is lost. xm technical support told me
Hey sorry i do not have an answer for this but did you get this fixed. i had the alpine cde124xm since june 2011 and had xm activated for a year with no issues. however this sunday it started to happen i shut the car off it looses the signal and needs to be refreshed. Sorry to post this here but i couldn't find a way to contact your directly. Just wondering if you found a fix
Jul 27, 2012 | Alpine CDE-124SXM - SiriusXM CD MP3 WMA...
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Pioneer xm radio suddenly stopped playing through my car radio. Got xm to restart signal back to device but that changed nothing. Sometimes when I wave my hand near to the xm device the car radio receives...
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Sep 15, 2009 | Pioneer AirWave XM2Go Satellite Radio...
No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
Sep 02, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
May 08, 2009 | Delphi SKYFi XM Radio Receiver
Can't get refresh signal to work for xm radio
to reset the radio - it must be removed from the dash and unplugged.
Be sure to write down any anti-theft codes if your radio requires them.
However - since your radio is getting the 2 channels - it is working properly. The problem lies in XM turning on your account.
Be sure to get the correct # off the radio... sometimes there is a transposition error with paperwork.
The number can be gotten by setting your radio to channel 0. This is your radio ID# required to activate the radio.
Your Radio is working fine - call XM and stay on the line until they activate your account.
I have a suspicion the number was written down improperly.
Be sure when you call that the car is on, and that it is tuned to station #1... also - it can take 15-20 minutes to activate - and must be left on for the duration to catch the activation signal that is sent out.
Here are the steps from XM to activate manually-
Get Your XM Radio Activated Online
Step1 Turn on your XM radio and tune it to channel 0. The display will read your XM radio's identification number. This number will include both letters and numbers. Write this number down and head to your computer.
Step2 Log onto the Internet and go to the XM radio website. A high speed connection to the Internet will make this go faster, but you can activate your XM radio online with dial up.
Step3 Click on the tab that says to activate a new XM radio. This will take you to a screen where you will enter your XM radio's identification number. Type this in.
Step4 Choose a screen name and password to make an account on the XM web site. The screen name should be something that you will easily remember. The password needs to be at least 7 characters long and include 1 capital letter, 1 lowercase letter, and 1 number.
Step5 Enter your personal information for the activation of your XM radio. This information will include your name, address, and email address. You will also need to choose which service plan you will want to purchase for your XM radio. Enter your credit card payment to finish purchasing your activation of your XM radio online.
Step6 Turn on your XM radio and tune it to channel 1. XM will send a signal out to your XM radio to activate it. You will need to leave the radio tuned to channel 1 for 15 to 20 minutes to activate it.
If you have additional questions or concerns - please ask me first before moving on to another expert.
Thanks for using FixYa!!
Apr 01, 2009 | XM Radio Audio Players & Recorders
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi XM SKYFi2 1016211B1 Satellite Radio Receiver Logo
568 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
