Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch axxis 3510 dryer doesn't dry clothes
When I try to dry my clothes on the timer option, the heat doesn't seem come on at all or barely comes on. When I try drying my clothes on the extra dry setting sometimes it stops when my clothes are still very damp.
I have a friend who is an appliance repair man so if I could buy the schematic or service manual he could could fix it, otherwise I want to know if I need a new power modual or a new operating modual.
Cheers, Laur
  • Anonymous Mar 12, 2014
    Model #WTMC3321US/03/FD8701/300278
    When attempting to restart, the display will show 20 (mins) even though I've pushed something different (ex. extra dry usually is 117 mins). Sometimes the dryer will run a few minutes after that and shut off again and sometimes it won't even restart. If it doesn't restart, I try to move the dial to other options and they too will flash 20 mins and not start. The only dial option that will work at this point is the air dry and if I run it on air dry for bit, then I can put it back on a heated drying option and it will work for awhile again and then repeat the same problem.
    When attempting to restart, the display will show 20 (mins) even though I've pushed something different (ex. extra dry usually is 117 mins). Sometimes the dryer will run a few minutes after that and shut off again and sometimes it won't even restart. If it doesn't restart, I try to move the dial to other options and they too will flash 20 mins and not start. The only dial option that will work at this point is the air dry and if I run it on air dry for bit, then I can put it back on a heated drying option and it will work for awhile again and then repeat the same problem. Model #WTMC3321US/03/FD8701/300278
  • 796 Answers
Click here
this might help you trouble shoot
Posted on Jun 26, 2008
    Brigadier General:
  • 3,614 Answers
Well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
  • micromaster
    micromaster Jun 26, 2008
    Do the checking on this parts:
    Vent
    For any obstruction in the vent duct from the dryer to the outside of the house. the duct must be clean and clear of lint or any other substance.
    Heating element
    If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
    Internal ductwork
    If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog,first, you have to substantially disassemble the dryer. To remove internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
    Cycling thermostat
    Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
    Hope this initial info/idea helps you..
    Kindly rate my solutions if this one solves/helps you correct the problem..
    Thank you
2 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: bosch axxis 3510 dryer
well first check the Thermal area inside the unit, if you have an idea doing this, it could possibly easily for you to do the work.. on the thermal area check for any burn fuse or any faulty parts relating or was connected on the thermal area.
Clothes are not drying
heating elament went out need to replace it
Aug 12, 2013 | Bosch Axxis WTA 3510 Electric Dryer
Jun 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch AXXIS dryer # WTA 3510 uc slipping / grinding sound when drum reverses direction. Difficult to turn drum by hand. Belt or motor?
drum baring or rollers if you can get belt off try to turn drum if it still hard to turn you will know its not the motor may be something in blower give it a try
Sep 30, 2010 | Bosch Axxis WTA 3510 Electric Dryer
My Bosch Axxis electric dryer Mod. # WTA3510UC 82/IV takes a few cycles to dry if it dries completely. The laundry doesn't seem to get warm no matter the setting. Have checked exhaust, cleared lint from...
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Oct 13, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I need advice on dryer for my kitchen.
This isn't an add its two different units that I have installed and are both condensation dryers. Which in my opinion is better for your needs and lacking venting.....LG and Miele also have 15 cycle so now the decision is what your needs and Budget. Prices range from 700-1500 but well worth the money. Bosch Axxis Condensation Dryer (model: WTMC8320US) you can machine-dry clothes without venting hot, moist air (or indeed any air at all). The Axxis Condensation Clothes Dryer condenses the moisture in the hot air to water and releases it through the water the need for ducting and a blower motor to help expel hot air. Ventless dryers make installation easy, fast, and very cost effective. And since little heat is lost when the air passes through the condensing chamber, it takes very little energy to raise the temperature back to optimal drying levels, thereby saving you energy. The Bosch Axxis ventless dryer features the unique DUO TRONIC system with 11 auto dry cycles that tailor the drying cycle to your clothing. And Bosch's exclusive DUO TRONIC system combines two moisture and three temperature sensors to automatically deliver precision drying. This machine virtually operates at the touch of a button to prevent over drying and damage to your clothes. With the stacking unit I think this is your best option due to keeping moisture, and later mold problems due too condensation. The Ariston Stackable Condensing Dryer ASL75CXSNA is the perfect choice for any home lacking venting capabilities and is the largest condenser dryer on the market, bringing the convenience of a compact laundry system to any home. Wrinkles are minimized with the innovative Pre and Post CreaseCare feature - periodically tumbling the clothing until you come back to remove it - and the handy Bidirectional Rotation of the stainless steel drying drum. Clothes gone musty from long closet stays can be quickly and easily refreshed with the ASL75CXSNA using the intuitive Air Fluff cycle, and the 12-hour Delay Timer allows for freshly-dried loads at your convenience.Key features include: spacious 16-pound load capacity; 180º reversible full metal door; removable lint filter; included stacking kit; Easy Iron option; and electronic Sensor Controls. The Ariston Stackable Condensing Dryer ASL75CXSNA has the high class, top performance, and compact convenience to be a welcome addition to any energy efficient home.Note: This item pairs with the matching Ariston Stackable Washers. I hope this was helpfull~ Have a good day
Feb 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch WTA4108 Dryer Not Heating
check and make sure you have 220 volts leving panel and @ the dryer motor runs on 110 volts takes 220 to heat
Oct 19, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
692 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
