Question about Zanussi Washing Machines
HOW DO I FIT A CONTROL KNOB COVER TO A ZANUSSI NEXUS WASHER
    President:
  • 1,462 Answers
Turn and gently push and it will click into poisition
Posted on Jun 26, 2008
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
How do you change the belt on a zanussi nexus fl 1082.iv got the top off and tryed to slip my hands down the back of machine to attach the belt to the motor and wheel,but just cant get the last bit on,and...
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
Oct 12, 2010 | Zanussi FLA1101W Front Load Washer
I have a zanussi nexus FL1082, and at the end of the cycle the clothes are still wet, meaning i have to re-sping it several times. Your advice would be most grateful..........thankyou.
Ther should be a filter located at the bottom front right of washer behind drop down flap, unscrew filter anti-clockwise and remove and clean.
Please rate my solution.
Thanks.
Nov 09, 2009 | Washing Machines
Replacing the door seal on Zanussi 1416W
No need to remove front cover.
Best way round the prob is to stretch the spring, this will make it easier to fit, it will help if you can get someone to assist in holding the spring, so that it does not come off as you are feeding it around the seal.
Don't stretch it to much, as it it will then be to slack, and may come off during washing.
Good luck.
Thanks.
Aug 06, 2009 | Zanussi FJS1225W Front Load Washer
Softener still in dispenser after wash cycle
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me
For more help go to live chat.
lenwest
Jan 30, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Nov 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
Main Control Knob Removal
Pull the knob off, some units have a set screw that holds it inplace but most are just tight fit. May need to pry it off. The screw that holds the control in the front plate is under the knob. Take the back plate off which is just behind the control. label the wires as you remove them or unplug one wire and put it on the same plug on the new control.
Feb 03, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
