Question about Kenmore 22422 Top Load Washer
Model # 23662200,will not spin
My top load machine will not spin.It seems to empty but the clothes are soaked. If I stick a pen in the swich I can make it spin by giving it a start.
  • 413 Answers
Look under the machine and locate the bottom of the gearcase. Inspect the bottom of the gearcase for oil. If oil is present, the gearcase will have to be replaced and the oil has probably migrated to the spin clutch causing it to slip during spin. Check your owners manual for limited warranty. The gearcase may have a 5yr warranty.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team
Posted on Jun 26, 2008
Wmtl79
is it spinning at all? if so then check ur pump for obstruction or bad propeller, if not check door switch, clutch, motor coupler, belt etc
Jul 09, 2014 | Hotpoint WMTL79 Top Load Washer
KENMORE FRONT LOAD WASHER MODEL # 417.44052400 WILL NOT SPIN. CLOTHES REMAIN SOAKING WET.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2011 | Washing Machines
When the cycle is done my clothes is still soaking wet
Hello becca_m2012 ,
Is the machine a FAV6800A or FAV9800A. If it is one of those models are you failing in Spin Cycle of the Wash Cycle with a dC or Uc error code to the display? Lets nail down the model number and I will try to point you the repair path......Rich
Nov 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The spin cycle doesnt seem to be working - clothes are coming out soaking wet - what could it be
Overloading, see if ur spin cycle wok ok by doing a empty load and watching it
Oct 26, 2009 | EuroTech EWF150 Front Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Spin water from clothes
i also have a kenmore model # 110.23832100. It drains the water but does not spin leaving the clothes soaked.
Jul 07, 2008 | Kenmore 23822 Top Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
Kenmore 22422 Top Load Washer Logo
229 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
