Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opener wont open makes clicking noise
Using an older 1/2 hp opener.  Has worked fine for many year, no operating difficulties.  After a big storm, it has stopped working.  When I press the button, it will make a clicking sound once, then again about one second later.  The green light flashes on the back of the motor.  any suggestions?
  • apaone Jun 27, 2008
    Similiar situation for me, but now clicking sound.  I will press the button on the wall and the light for the garage door opener will come one but the door won't open (the motor doesn't start up).  Any solution?
  • lindsasm Jun 27, 2008
    Wow, hard to believe mine started doing the exact same thing yesterday.
    Scholar:
  • 91 Answers
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Posted on Jun 27, 2008
After a lightening storm the light on my Craftsman garage door opener work. I changed the bulb but that's not the problem Thinking it may be the fuse, but where is it?
I'm guessing that some of the electronics got fried by a voltage surge.
If you can find your model number you can probably get a replacement board at sears parts direct,
http://www.searspartsdirect.com/
Aug 29, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
I have an older LiftMaster opener (1/3 Hp - 1991 vintage). I have had two older replacement universal type remotes that worked fine. Lately one of the remotes stopped working with the opener. Changed...
Hmm tricky situation try unplugging it for atleast 2 hours and remember any device usually handles one code at a time so if your using two remotes together with different codes that will happen thats pretty much all i can think of at moment
Apr 26, 2017 | Chamberlain Televison & Video
I have a 1/2 hp Sears Craftsman Garage Door opener about 18 months old when operating the remote within 5 feet or less of the opener the opener works properly. Upon exiting the Garage about 10-12 feet away...
The difficulty is determining if your remote or the receiver is bad. If you have another remote that works as it should then it is the remote. If you just have the one remote there is no way to tell which is bad.
Jul 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP Garage Door opener problem
The remote and the keypad work through a signal sent to the receiver while the wall console, as you said it's wired directly to the opener, so it's likely that the receiver is shot. I'd try reprogramming the remote to just rule out the chance that all code wasn't erased first. (Press the learn button on the back of the operator head, stand back 5 feet and within 30 seconds slowly press the remote button a few times to see if it operates the opener). If this doesn't work, you can install an external LiftMaster universal receiver with the correct frequency and you should be good.
If there's a purple antenna hanging off the head, this is a 315 freq, use a 356LM, if black it's a 390 freq, use a 635LM receiver.
Then you'll have to reprogram your remote and keypad to the receiver.
Since there's also the issue with the light, there's also a possibility the circuit board got fried. Did you have any storms lately?
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2hp thinks it is not all the way up and will not go down
It is really a common problem for lightning or electrical surges to take out the logic board. Big expense too.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener stoped working after a storm.
TRY TO REPROGRAM THE REMOTES TO THE OPENER - THESE UNITS CAN LOSE THE MEMORY DURING STORMS.
I WOULD SUGGEST ADDING A SURGE PROTECTOR AT THE PLUG IN TO PREVENT DAMAGE TO YOUR UNIT IN THE FUTURE.
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not working
clicking noise usually is from relays on logic board. you over-heated unit. wait 25 monutes for motor to cool.
Aug 02, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener does not work
My Garage door goes down half the first time I'm attempting to close it; then closes completely the second try. What's the problem?
Jul 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
3,082 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
