Question about Cuisinart DLC-2007 7 Cups Food Processor
Machine won't run
I put everything in place in the food processor just as described in the manual and when I hit power the red light goes on but the blade won't move. This happens EVERY single time I want to use it. It literally takes me about 20 tries of taking out the pusher and unscrewing the bowls, etc...and doing it all over again to get it to finally run. I'm caught in mid recipe right now and can't get it to go. I'm ready to throw it out the window and buy a cheaper priced but easier working machine. The safety cautions on this are unnecessary if it means you can't use the machine. same thing w/ me, only the light goes on etc, except that i can't get to use it even once! niev inong, philippines
  • niev Aug 03, 2008
    I put everything in place in the food processor just as described in the manual and when I hit power button, only the red light goes on but the blade won't move, no sound, no indication of anything getting stuck, only the red light is on. i've never used it, even once!
  • Cuisinart Master
  • 19,396 Answers
It is not a bad motor, dirt, or anything stuck up. It is the machine sensor. The cup and the processor when screwed propery must press a little switch sensor.
If they are not mounted properly, the sensor is not pressed, you do not get the OK light and machine does not operate.
Assuming that you are assembling cup and blades in the right way, the cup is not applying right pressure on sensor or sensor get stuck.
Check your guaranty terms, if machine is still under guaranty call the number printed on last pages of your owner manual to validate guaranty and get replacement/support.
Posted on Aug 03, 2008
  • Ginko
    Ginko Aug 03, 2008
    Wordvet, if you see my post and Benimur, post information to the user, is just the safety switch sensor, but user cannot see our solution because of "there is a solution ahead of you" feature.
    Good luck
  • Ginko
    Ginko Aug 03, 2008
    There can also be an additionaly switch on the cover, as addressed by maklean, the cover must be screwed in right way or no start.
    Genius:
  • 1,665 Answers
See if also provided a power push switch in line (it must be pushed in for motor to rotate.
( http://www.cuisinart.com/share/man/58_man.pdf )
  • 813 Answers
Chk the moter is it working proper
Posted on Jul 28, 2008
    Genius:
  • 2,035 Answers
This could the problem with motor carbon brush worn out you need to replace then ,Please give it local service center and get it fixed...
Good luck...
    Brigadier General:
  • 6,966 Answers
I can imagine your frustration (good learning curve in my wife's kitchen). In any case, the safety features are meant to protect you since this food processor uses a relatively strong motor. The safety switch incorporated is based on how the cover is placed to the machine. If you fit the cover slowly, there is a possibility that it will not snap the safety switch to the on position. What is needed is a quick positive move to lock the cover into its position. Assembling the the unit therefore would require snappy actions not slowly sliding them into place.
Of course being in the Philippines would help as most friendly neighborhood electronic techs would be able to help you adjust the safety switch to make sure that they latches to ON easily. You can even try any of the numerous electronic shops in Gonzalo Puyat St (formerly in Raon) if you are somewhere in Manila. Of course, I would not suggest that you ask them to bypass the safety feature.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 26, 2008
    Genius:
  • 2,785 Answers
Plz get it serviced as it is having hardware problem
    Guru:
  • 859 Answers
You have something in your machine, be it dried food, dirt, something hindering your lock out switch to engage correctly.
Take everything out and off the base then turn it over and knock it pretty ******* a counter with some newspaper or cardboard underneath until you dislodge what ever is stuck inside.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Aug 03, 2008
    OK. No on the first solution.
    You have a bad solder connection in your motor to one of the brushes that contacts with the armature. This would cause the intermittent running and eventually not run at all.
    If you are handy enough to disassemble the motor assembly, you can easily check this and hopefully the copper wire is not loose in the carbon contact but on the copper wire to the motor housing circuit.
    These brushes have springs behind the carbon plug to put pressure on the armature. Sometimes these just get stuck in their housing. You could use a dental tool or bent paper clip to push the brushes down on the armature and release them from their stuck housing.
    Regards,
    Worldvet
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
I plug it in, turn it on, the red light goes on but nothing happens. same thing when i hit pulse. Any ideas what could be wrong?
hello,
the problem is from the connection i.e power connection
that supply electrical force on your processor
this means that there have been a power fail on the propeller ,
what you need to do tofix up this problem is to unscrew the processor then trace the wire down to the propeller you will fine the disconnected wire from the propeller then fix back to the propeller unit but if there is no sign of disconnection from the connection then it means that the wire are weak ,
it will need to be replace with a better one which you can get in the store.please note before you can do this assignment you will have to put off all source of power supply to your processor
thank you.
Jun 13, 2010 | Cuisinart DLC-2014 PowerPrep Plus Food...
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
I need a part
Are you looking for the blade assembly for the chopping bowl? It has the blade and removal tool. I have an order of parts coming that I won on eBay, which I wanted for the DoughWorks, plus to replace my lid for the Vegetable Chef, as mine has a broken strap. There are duplicates of parts I won't need in it. Please send an email to clay_pots_47@msn.com and put La Machine Parts in the subject line and describe what you need. I can't help those of you asking about La Machine II, entirely different machine. I only have parts to fit the original Moulinex 500 series machines.
Nov 27, 2008 | Moulinex DG6 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Food processor
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
It won't start
The power lights go on put the machine does not run.
Nov 22, 2007 | Cuisinart DLC-5 Food Processor
Cuisinart 11 cup processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Oct 13, 2007 | Cuisinart DLC-2011 PowerPrep Plus Food...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Cuisinart DLC-2007 7 Cups Food Processor Logo
434 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
