Question about Cell Phones
Emergency download mode is on the phone - Cell Phones
  • 4 more comments
  • Anonymous Aug 14, 2008
    my Samsung M300 went into "Emergency download mode" unable to power phone down/or use any of the keys.
  • bbf3030 Oct 08, 2008
    My phone did that, too. After I got out of the shower, I started texting, but it took about 30 minutes to show that message.
  • mauriciojohn Dec 13, 2008
    emergency download mode is on my phone and idk what to do
  • 245895 Feb 09, 2009
    i have the same problem i turned on my instinct phone and all of a sudden it went into emergency download mode idk what to do
  • alhoak Apr 19, 2009
    None of my keys will work either
  • Anonymous Apr 29, 2009
    Does anyone know what "Emergancy Download Mode" means on a Samsung cell??????????????????????????????????????????????
Just take out the efin battery noobs
Posted on Feb 21, 2010
I was told that it means that the company software has been wiped off. so u have to send it to samsung to get it reinstalled, costing about $50
Posted on Aug 09, 2010
Try
1. pressing shift and then space five times.
2. press shift and then end.
3. remove battery and reinstall it.
Posted on Oct 26, 2008
2 Suggested Answers
  • 89 Answers
SOURCE: Download Mode
Let your phone die, and then charge it up and see if it happens again. If it does, try to have it repaired or exchanged.
Posted on Apr 07, 2009
Need to 'hard reset' my Samsung Galaxy Europa
I attempted the above in order to hard reset my Europa i5500. However, it didn't work, and instead just went back to the "enter address/password" screen. I've attempted to connect to Kies, but to no avail, Kies doesn't register that the product is plugged in. I can get the phone onto download mode and emergency download mode, however neither are helping me much. Any suggestions?
Nov 30, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
I was charging my lg phone on my laptop so i decide tu download some music i unplugged the phone and then plugged it back and a window on my laptop appeared to dowload and lg site so the computer can...
You have bricked your phone by disconnecting it while it was updating. Emergency mode is the safe mode of phones, you should never disconnect your phone while it is updating or transferring files.
Apr 28, 2011 | LG GT540 Cell Phone
I turn on my phone it goes to a screen saying Emergency Download
Wait does it say emergency mode only? If so this has happened to me many times on this phone.
Turn off the phone and remove the battery. In there will be you should see the SIM card. Pull out the SIM and put it back in. Put back the battery and turn on your phone.
For some reason on these phones the SIM card gets dislodged. When it does the phone won't work because the SIM card is what makes the phone your number etc. All cell phones, that have no service otherwise will be able to call 911. Apparently it is a law, so that is why your phone is on emergency mode. Without the SIM card the phone is a phone without service and will therefore only work in emergency mode.
I hope this is what you meant.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
Samsung omnia in emergency mode. cannot download mms image. Why how did it get in emergency mode??
dial *228 on phone...hit send. when automated message starts hit the number 1. you'll hear music. Just wait until it says phone is successfully reprogrammed. I just had the same problem and verizonwireless tech support helped me. Hope it works for you!
Aug 04, 2009 | Samsung Omnia Cell Phone
My phone is stuck on an "emergency download mode" screen.
Did you ever find a solution to this problem!? Mine has the same screen...
Jun 16, 2009 | Pantech Matrix Cell Phone
Emergency download on sprint instinct
Let the battery die completely, it should stop. If the problem persists, take your phone into the store, it needs to be repaired or replaced... also check for software updates.
May 27, 2009 | Samsung Instinct Cell Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Download Mode
Mar 05, 2009 | Samsung Instinct Cell Phone
Emergency Download
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Dec 17, 2008 | Samsung SPH-M300 Cellular Phone
Cell Phones Logo
2,529 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
